System Restore
mty
As andsome says, have you tried safe mode.
Ti get to it tap the F8 key at start up and select safe mode, you should then be able to access system restore to undo your last one.
You will need a PS2 keyboard to boot into safe mode as no USB drivers are loaded.
This isn't strictly true with all keyboards and rodents. I can use mine even for reinstalling the OS.
tried safe mode still cant access system restore
