Keyboard Problem
xentrumx
I got a problem with my keyboard:
The keys alt and alt gr dont work. Its a german keyboard. I have been useing it for a long time now and this problem started when I installed a tool for disabling the windows keys, but now when I press alt gr calculator opens. So now I cant do the shortcut for task manager or @ sign or alt tab through programs. Is there a way to delete the keyboard configuration and at startup it is resetet? Or generaly reset it?
I dont have the driver cd anymore cause the keyboard is already very old. It is automaticaly recognised by windows xp though.
Thanks for now
Thanks for now
Can you find drivers on line?
if you have MS Office installed, you would probably have the Proofing Tools installed
if so, you can access the keybaord configuration by right-clicking the task bar [bar with the startbutton on it]
you can change the settings there, more info here
i recommend to set the settings to the default german settings
let me know if this helped you
