Explorer 6.0 Problems
my homepage is changed by some outside force --- even when i put the site on the restricted sites list. they are sites like youfindall.net and xupiter.net (yahoo sites?). yahoo has also inserted its own toolbar on the explorer window, and i am unable to get rid of it? if someone understands my problem and could help, i would be forever grateful.
keith buchanan
Welcome to the forum Keith, I'm afraid you have been hijacked, Xupiter is a bugger to get rid of but Spybot search and destroy will clear it, go to here, download, install and update it, then boot in safe mode and run spybot allowing it to remove the spyware, then you should be able to restore your homepage to the one you want. Post back if any further problems
Under the Spybot - Immunize tab you can also set your IE start page to be locked - thus preventing any further unauthorised changes.
