colrich Posted July 4, 2007 Report Share Posted July 4, 2007 I have talktalk broadband with a modem supplied by them. Often when I swich on my computer and dial my broadband connection it fails to connect and I get an error message. Disconnecting and reconnecting the modem (and waiting for the ADSL light to stop flashing) usually cures the problem, though sometimes this has be done twice. Does anyone know how to cure this tedious problem? Would buying a more expensive modem be the answer? Quote Link to comment Share on other sites More sharing options...
doug Posted July 4, 2007 Report Share Posted July 4, 2007 Not sure if this will help but I was having quite a few problems with my TT router.- a SmartAX MT882 - which was connected to my PC via a USB port. I invested in an Ethernet card (£6.50 + £2.50 for the cable) and connected using that. No problems since - so far. I followed a link given to me pointing to TalkTalk Quote Link to comment Share on other sites More sharing options...
doug Posted July 4, 2007 Report Share Posted July 4, 2007 You might find some detailed info in this subsection more Quote Link to comment Share on other sites More sharing options...
-pops- Posted July 4, 2007 Report Share Posted July 4, 2007 An Ethernet connection is much better than USB and if you are on USB, check if your computer already has an Ethernet connector. If it doesn't, as doug says, an Ethernet card won't cost very much.If your modem is USB only it is worthwhile getting a better quality model with Ethernet. Quote Link to comment Share on other sites More sharing options...
colrich Posted July 4, 2007 Author Report Share Posted July 4, 2007 Thanks for advice to date, I'll search the site referred to. I'm not using a router by the way, what I meant was I have a direct connection by wires to the computer from the phone line with talk-talk supplied Sagem f@st modem in between. Quote Link to comment Share on other sites More sharing options...
Boris Posted July 4, 2007 Report Share Posted July 4, 2007 Have you tried updating the drivers for the Sagem USB modem ? Quote Link to comment Share on other sites More sharing options...
colrich Posted July 4, 2007 Author Report Share Posted July 4, 2007 I didn't know they could be updated! The drivers were installed when I joined talk talk and the modem was supplied at the same time, and I've had this problem from the start (about 12 months ago). Sorry to be thick but- how do I update? Quote Link to comment Share on other sites More sharing options...
andsome Posted July 5, 2007 Report Share Posted July 5, 2007 A friend of mine has similar problems with TT connected via USB. TT themsleves are not much help, even if you can understand the Bombay accent. Quote Link to comment Share on other sites More sharing options...
Boris Posted July 5, 2007 Report Share Posted July 5, 2007 I didn't know they could be updated! The drivers were installed when I joined talk talk and the modem was supplied at the same time, and I've had this problem from the start (about 12 months ago). Sorry to be thick but- how do I update?I expect yours is this one ? SAGEM F@st™ 800Details :-http://www.sagem.com/support/site/modele_f...amp;produit=141To check - on the bottom of the modem there is the model number - e.g. SAGEM F@ST 800 E2L PE on the old one I have here.If so - the latest drivers for it (Driver W.A.4.8 for all operators (Vista compatible)) are found here :-http://www.sagem.com/support/site/driver/S...st800-A_4_8.zipTo update the drivers click the setup.exe file in the .zip Quote Link to comment Share on other sites More sharing options...
colrich Posted July 5, 2007 Author Report Share Posted July 5, 2007 Boris: I'll give it a try. Thank you for taking the trouble to answer my question. Any advice from any other quarter will also be welcome. Quote Link to comment Share on other sites More sharing options...
