Formatting problem
cryptic
I'm having a problem formatting my hard drive. I have a C and D drive.. I formatted them both and the D drive wiped everything as it should have but when I try to format my C: drive it seems to work.. It gets to 100% but when I restart my computer all of my old files are still there.. any idea why this would happen? I'm using windows xp Home
This is just an educated guess. I suspect that if you try to format the C: drive from within Windows - the operating system is not willing to destroy itself.
I imagine to format the C: drive you need to do so from an appropriate CD.
I am sure one of our experts will come along and put us right.
In XP you need to set the computer in the BIOS to boot from CD. Then you can format and reinstall XP. :D
