alexia_net Posted March 3, 2008 Report Share Posted March 3, 2008 Hi. I have seen once on a server that when it boots up on the desktop it has the configuration of the system: operating system, processor, ram, video card. How can this be done on a XP or Vista computer? There was no additional software used. Thank you! Quote Link to comment Share on other sites More sharing options...
alexia_net Posted March 3, 2008 Author Report Share Posted March 3, 2008 Hi. I have seen once on a server that when it boots up on the desktop it has the configuration of the system: operating system, processor, ram, video card. How can this be done on a XP or Vista computer? There was no additional software used. Thank you! Anybody? Quote Link to comment Share on other sites More sharing options...
Irene Posted March 3, 2008 Report Share Posted March 3, 2008 Hello alexia_net, welcome to the forum. :D In XP Home...If you press Start, then Right-click My Computer, then select Properties, you should get the information which you are looking for.Let us know if that's ok. :) Quote Link to comment Share on other sites More sharing options...
Dencandy Posted March 3, 2008 Report Share Posted March 3, 2008 To get this information on the desktop immediately after startup I imagine this must be done using a special start up script or/and by using the System Configuration Utility. I know little about either and don't advise messing with them unless you know what you're doing.Or it could be done by getting a programmme like PCWizard to start immediately after booting (using Task Scheduler, for example). You then get it to display the results on the screen showing all your hardware. You could experiment with that a little without doing too much harm. Quote Link to comment Share on other sites More sharing options...
mark2 Posted March 3, 2008 Report Share Posted March 3, 2008 The only item I've come across is BGinfo http://technet.microsoft.com/en-us/sysinte...s/bb897557.aspx but no info regarding graphics Quote Link to comment Share on other sites More sharing options...
Dencandy Posted March 3, 2008 Report Share Posted March 3, 2008 A lot quicker than running PC Wizard, I imagine. It's only 360 KB.What about a little script, mark2, that would display the System (Generel) tab from the Start Up Folder immediately after booting? Quote Link to comment Share on other sites More sharing options...
mark2 Posted March 3, 2008 Report Share Posted March 3, 2008 What about a little script, mark2, that would display the System (Generel) tab from the Start Up Folder immediately after booting?Placing BGinfo in the start up folder will generate the info as windows boots. Quote Link to comment Share on other sites More sharing options...
alexia_net Posted March 4, 2008 Author Report Share Posted March 4, 2008 The only item I've come across is BGinfo http://technet.microsoft.com/en-us/sysinte...s/bb897557.aspx but no info regarding graphicsHi. Thank you for your answers. I was looking for something like BgInfo. It seems to be ok. I will run a few more tests. Thank you! Quote Link to comment Share on other sites More sharing options...
