Analyzing and defragmenting problems. Please help!!
yod
Hi,
I've been going round in circles for a few hours now trying to sort my sisters laptop , she has nearly no space left (7%) on her hard drive so was trying to clean it up for her. So went to disk-defragmenter to start off but have run into problems.
When trying to analyze the c: it was coming up with the message “C: might be corrupt run chkdsk /f ”
I scheduled it and restarted the laptop so it could run it ran it but it found nothing wrong, so went back into disk defragmenter and tried analyzing the c: again but did nothing and then came up with the message "The connection to the defragmenter engine has been lost"
I’m stuck as what to do next, could some one please advise me? The Laptop has Windows XP Home edition with Service pack 2 on it if that is any help.
Any advice would be much appreciated!
Yod
CCleaner (scroll down to free download from FileHippo) to clear out the immediate rubbish?
Clean it with http://www.ccleaner.com/ that might free up a fair bit of space if it hasn't been used for years.
Snap!!! :D
Thanks for the reccomendation, I have run it and analaysed the C: and it has said it can cear a considerable amount of space. But I have a question: its listed all the things it will clear now some of these are cookies, temporary files etc which is fine but some appear to be some word fies and pics. now she isn't here for me to ask but will these files be duplicates and previous deleted files or might they be current files on her c:? (Hope that makes sense.)
It will only delete such files (word files and pics) if they are already in the Recycle Bin.
Or temporary files. Often when creating a word document, you will find a hidden file with the same name with a tilde in front of it.
For example, I am working on something called work.doc. Windows will create a temporary file called ~work.doc as a "live backup" so that if my computer was to crash, I could recover this file. Once you click save, all changes in ~work.doc are written to work.doc
I've used CCleaner for years, and have used Defraggler since 1.0 BETA. I recommend and use both of them.
I would not clean cookies at the first run; there are probably many cookies (for website login, etc.) that your sister may want to keep, so cookie cleaning should be configured (Options | Cookies) before actually run. Otherwise the default settings should be safe.
P.S. Don't run the Registry cleaner; this will not help with the disk space.
