Coreper Posted June 26, 2008 Report Share Posted June 26, 2008 a while ago, when installing my motherboard, i got this small part with my motherboard, but i never knew where to put it...maybe you know what it is and where to put it:i think it is a small beeper sound thingy for on your motherboardthe motherboard i use is the Asus P5N32-E SLIthanks in advance Quote Link to comment Share on other sites More sharing options...
catgate Posted June 26, 2008 Report Share Posted June 26, 2008 I think you may be right. Quote Link to comment Share on other sites More sharing options...
Coreper Posted June 26, 2008 Author Report Share Posted June 26, 2008 but where do i need to put it/connect it to/plug it in?it doesnt say anything about it in the manual... Quote Link to comment Share on other sites More sharing options...
-pops- Posted June 26, 2008 Report Share Posted June 26, 2008 I'm fairly sure it's a beeper. They are usually fitted on the collection of headers that are placed bottom, right of the motherboard - the manual should indicate where.However, some motherboards, especially ASUS ones, don't have a beeper header (I've had several like that) but the beeper is supplied in the pack of bits as a matter of course. I suppose they just produce a standard pack of accessories.If your machine is going OK without the thingy, leave it out. Quote Link to comment Share on other sites More sharing options...
ced Posted June 27, 2008 Report Share Posted June 27, 2008 I'm fairly sure it's a beeper. They are usually fitted on the collection of headers that are placed bottom, right of the motherboard - the manual should indicate where.However, some motherboards, especially ASUS ones, don't have a beeper header (I've had several like that) but the beeper is supplied in the pack of bits as a matter of course. I suppose they just produce a standard pack of accessories.If your machine is going OK without the thingy, leave it out.unless you want your pc to make beeping sounds again ^^ (can be usefull when broken, but most of the time just annoying. i think that's also the reason why it looks like some plugin device, and not some nice speaker which you can hide in the case front.) :P Quote Link to comment Share on other sites More sharing options...
Coreper Posted June 27, 2008 Author Report Share Posted June 27, 2008 haha, okthanksdoes anyone also know how the male connector for this [female] device looks like? Quote Link to comment Share on other sites More sharing options...
-pops- Posted June 27, 2008 Report Share Posted June 27, 2008 If they're there, they are pins projecting from the M/B.I really wouldn't worry too much about it if the machine is running OK. Quote Link to comment Share on other sites More sharing options...
catgate Posted June 27, 2008 Report Share Posted June 27, 2008 haha, okthanksdoes anyone also know how the male connector for this [female] device looks like?As pops said there is usually a cluster of pokey uppy things in one corner of the MB. On to some of these you will have connected various things, some of which are the GO button, front panel connections,speaker connectors etc.There are usually marking on/near them, for which you may need a magnifying glass, which will indicate which is for what, if you can decipher it. Quote Link to comment Share on other sites More sharing options...
Coreper Posted June 27, 2008 Author Report Share Posted June 27, 2008 yeahi dont think there is a connector for itthanks for the help guys!just to comfort you: i wont connect it ;)the primary reason i got back on this, was because i found this awesome Bleeper Music Maker program, which uses the beeper device to make music, which is rather cool ;) Quote Link to comment Share on other sites More sharing options...
andsome Posted June 27, 2008 Report Share Posted June 27, 2008 yeahi dont think there is a connector for itthanks for the help guys!just to comfort you: i wont connect it ;) the primary reason i got back on this, was because i found this awesome Bleeper Music Maker program, which uses the beeper device to make music, which is rather cool ;)What temperature is it then? Quote Link to comment Share on other sites More sharing options...
Coreper Posted June 27, 2008 Author Report Share Posted June 27, 2008 hahawhy cant you guys ever take something seriously XD Quote Link to comment Share on other sites More sharing options...
andsome Posted June 27, 2008 Report Share Posted June 27, 2008 hahawhy cant you guys ever take something seriously XDLow temperature can be serious if you feel the cold. You said it was cool, so I enquired as to how cool it was. Please reply in degrees Celsius. :D Quote Link to comment Share on other sites More sharing options...
