Default PM settings
catgate
My experience has been such that I assume the PM default setting are Received messages are Saved by default and Sent messages are Erased after sending by default.
Is this so and is it possible to set Sent messages to be Saved by default?
At the bottom of the message you can save it to your sent items folder. :D
Yes I know that.
I invariably forget, because almost everything else in the computer world automatically saves, or at least prompts you.
I was thinking, like Boris, that it was not possible, otherwise there might have been a clue somewhere. It seems odd that the In messages are savable and the out ones are not.
Hey Ho ....Thank you both.
Change to Thunderbird, all mine get saved.
I'm not sure that follow you, rong.
I'm on Thunderbird for my normal emails, but I don't see how that comes into the WF PM system.....but then I do sometimes take a little while to catch on.
