Ater GRUB - Error and won't load Ubuntu
Hb_Kai
When I was using Ubuntu a few minutes ago it suddenly crashed on me and switched itself off.
Now each time I try to load the operating system I get this error and it won't load anything after it.
[0.832256] kernel panic - not syncing: VFS : Unable to mount root fs on unknown block (0,0)
To be honest I've got no idea what this means. I have the idea it might be that the Ubuntu files have gone corrupt somewhere but can't think of anything else.
But I have a feeling it's something to do with what I was doing beforehand. I was using the internet and downloading some updates when it logged itself off randomly right when the updates began to install. Got no idea why though. So I logged back on and carried on thinking the updates may just save over each other.
Does anyone know what this problem is and if I'm going to have to re install Ubuntu?
I don't know anything specifically about Ubuntu but, don't you have a backup or clone of the drive?
Contrary to what some people think, backups are not the exclusive preserve of Microsoft systems. All hard drives are prone to failure - either catastrophic where the drive suddenly dies completely or progressive in which faults gradually develop and which sooner or later become apparent by inconsistency in performance.
The only thing close to is there's a copy of each choice on the GRUB boot menu like.
Ubuntu, kernel (loads of numbers) -generic
Ubuntu, kernel (loads of numbers) -generic (recovery mode)
Ubuntu, memtest
Microsoft Windows XP
So I have two choices to load Ubuntu. I don't exactly know how but on the second one that says generic at the end, it will load from there and kind of looks like Windows Safe Mode.
If I have to use the recovery mode, I don't know much about Ubuntu yet and don't really know how to use it.
you got a kernel panic
best way is to choose an older kernel in the grub menu:
on the grub menu you have the different kernel versions
the top one is the latest
the second one following is the recovery mode for that kernel
the next one down is an older kernel and so on,,,
oh and take the advice mentioned above - learn how to back up in linux
also - post in ubuntu forums to solve the kernel panic situation, provide your kernel number and ubuntu version
I tried using an older one but the problem persisted... So I removed Ubuntu and restarted. :)
Cheers anyway, :) And yeah. I will be reading up about linux backups too.
Booting from an older kernel as found in the GRUB startup menu will usually help.
Otherwise boot from a LIVE linux (Ubuntu) CDROM and see what the error is when mounting the ROOT / filesystem.
You could also run a fsck (filesystem check) on your harddisk devices.
... :beach:
