TallyTiger Posted March 28, 2009 Report Share Posted March 28, 2009 I am running Windows XP SP3 on a desktop. It has McAfee Internet Security. Today, the computer shut down by itself and when I restarted it there were several application errors but most importantly I notice I had no internet connection. I discovered that there was no network adapter in control panel and upon further investigation I found that no devices show up under Device Manager. It won't let me search for new hardware. When I try to run McAfee to do a scan, I can double-click on the short cut and a the initial graphic displays then nothing. I'm afraid I've got some big issues here.HELP! Quote Link to comment Share on other sites More sharing options...
doug Posted March 28, 2009 Report Share Posted March 28, 2009 Have you tried doing a Restore to an earlier point? Don't suppose you have a backup? Quote Link to comment Share on other sites More sharing options...
andsome Posted March 28, 2009 Report Share Posted March 28, 2009 Have you tried doing a Restore to an earlier point? Don't suppose you have a backup?If not, once up and running again invest in a program such as Acronis or similar, and a plug in external hard drive. :D Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted March 28, 2009 Report Share Posted March 28, 2009 If you are using on-board Ethernet, you could try a PCI Ethernet card as the on-board adaptors do sometimes go kaput.http://www.microdirect.co.uk/Home/Product/...10-100mb-Retail Quote Link to comment Share on other sites More sharing options...
TallyTiger Posted March 28, 2009 Author Report Share Posted March 28, 2009 Have you tried doing a Restore to an earlier point? Don't suppose you have a backup?I looked and all of my restore points are gone. This smells of some kind of intrusion. Can you undelete restore points? Quote Link to comment Share on other sites More sharing options...
TallyTiger Posted March 28, 2009 Author Report Share Posted March 28, 2009 Have you tried doing a Restore to an earlier point? Don't suppose you have a backup?If not, once up and running again invest in a program such as Acronis or similar, and a plug in external hard drive. :DThank you. I'll try that. Quote Link to comment Share on other sites More sharing options...
Dencandy Posted March 29, 2009 Report Share Posted March 29, 2009 I also suggest you try to start your computer in safe mode & check everything from there. If you don't know how to start in safe mode please let us know. Quote Link to comment Share on other sites More sharing options...
