Monitor connections
jay
Hi
My monitor is a Viewsonic VX2260wm and has both DVI-D sinle link, and VGA sockets. When I connect the DVI-D cable there is "no signal" message onscreen. It works OK with the VGA connected to the graphics card, but not to the VGA on the motherboard. I have both cables connected at the moment, but I thought that to get best performance the DVI-D should work.
Thank you
Hi
Thank you
It is not surpising that it will nor work plugged into the mother board if your system is set up to run from a graphics card.
Someone who knows better about these things than I do will no doubt turn up before long, and to give him a better chance of helping you you could perhaps give more details of just exactly you are running, both machine details and operating system.
You should only have one cable connected between the PC and your monitor.
Remove the cable between the VGA socket on the motherboard and the monitor.
Do you have a DVI connector on your graphics card ?
I have a DVI out on the graphics card. It has 3 rows of 8 pins (plus flat pin with 4 around it), the cable supplied with monitor has 9+9 plus flat pin. Would I need to get another cable to suit, or would the supplied one fit?
The VGA is in graphics card at moment.
