How to convert RAW File system
Shijo
Hi friend
I have an issue with my 8GB pendrive. Once I connect the pendrive to my system it prompt to format the drive. But if I try to format it says write protected
Try to format from DOS but same. In device manager it shows the file system is RAW. I try to format through windows OS CD but unable to format
Is there any way to convert this to ntfs or fat32. I tried CONVERT X: /FS:NTFS but it shows unable to format RAW file system.
PLEASE HELP ME TO RESOLVE THIS ISSUE
This reverting to RAW is a common occurrence with pen drives - and with other drives connected via USB.
It is essential always to disconnect any writable device from USB using the proper disconnect facility.
It means really that the drive should be consigned to the rubbish bin.
Download GParted, burn the ISO to a CD then use it to format your pen drive.
/>http://download.cnet.com/GParted-LiveCD/3000-2094_4-10698802.html
hi Alan
i tried which you given software
i am sorry its not working and this software manual says first need to copy a file to the pen drive. but i am not able to open my pen drive at all.
Hi friend
Shijo,are you telling me you could not find ANYTHING to help you with this by searching the web? :uhm:
I don't use pendrives but I have read through several threads that have ended with success dealing with this issue:--->disable write protection on pen drive
Another part of my previous reply is of importance:
It used to be said about USB being "hot pluggable". That may well be true but USB is certainly not hot unpluggable. It is vital that USB devices with any read/write capability are disconnected using the Safely Disconnect facility available.
