cinque8 Posted April 23, 2011 Report Share Posted April 23, 2011 Hi,When I type anything into a dialog box such as this one the letter "k" is automatically entered many times kkkkkkkkkkk and I have to delete it to complete a sentence. My first thought is that it must be some kind of virus, but I have scanned my computer with two different anti virus programs and they have turned up nothing. Anyone else having this problem?Thanks-cinque8 Quote Link to comment Share on other sites More sharing options...
-pops- Posted April 23, 2011 Report Share Posted April 23, 2011 Are you able to do a System Restore to a time before this started happening? Quote Link to comment Share on other sites More sharing options...
pawz7 Posted April 23, 2011 Report Share Posted April 23, 2011 could it simply be a stuck key? Quote Link to comment Share on other sites More sharing options...
AlanHo Posted April 23, 2011 Report Share Posted April 23, 2011 Are you using a desktop or laptop computer.If desktop - can you try another keyboard. Quote Link to comment Share on other sites More sharing options...
cinque8 Posted April 23, 2011 Author Report Share Posted April 23, 2011 Even as I type this reply I am having this problem. I use a program that is better than System Restore called ERUNT http://larshederer.homepage.t-online.de/erunt/ I will try it today. As for the k key being stuck, I have pounded that key repeatedly, and blown compressed air under it but no luck. I am using a laptop, but as a last resort I can change the keyboard. Thanks for the replies!-cinque8 Quote Link to comment Share on other sites More sharing options...
AlanHo Posted April 23, 2011 Report Share Posted April 23, 2011 Does it only misbehave when typing into a dialog box? - what happens if you type text into Notepad or a word processor? Quote Link to comment Share on other sites More sharing options...
cinque8 Posted April 23, 2011 Author Report Share Posted April 23, 2011 In word or wordpad I don't have the problem. I ran System Restore and ERUNT but no luck. I have an older Dell Latitude D610. I took the keyboard out and sprayed it with compressed air, and as I am typing this I am not having the problem for the first time. So I will see what happens.Thanks!-cinque8 Quote Link to comment Share on other sites More sharing options...
Scythe Posted April 23, 2011 Report Share Posted April 23, 2011 If it's an issue with just dialogue boxes, try a different browser, you might be experiencing an odd bug. I suggest firefox. Quote Link to comment Share on other sites More sharing options...
cinque8 Posted April 23, 2011 Author Report Share Posted April 23, 2011 That's a good point! But since I blasted the keyboard with compressed air, the problem has stopped! I am being told that this problem is not all that unique for an older laptop like mine. I am running a Dell Latitude D610, a real clunker! :D Thanks!-cinque8 Quote Link to comment Share on other sites More sharing options...
cinque8 Posted April 23, 2011 Author Report Share Posted April 23, 2011 BTW,I am kind of new around here, but I noticed a couple of references on this forum to the How-TO Geek forum. So I guess it is ok to say that it was VistaMike on the How-To Geek forum who told me that he has seen this before and offered two solutions: 1. Blast the keyboard with compressed air2. I am not making this up: brush the keypad with heated isopropyl alcohol.Uh...., not wanting to burn my house down I elected to go with the compressed air, but Mike swears that both methods work.-cinque8 Quote Link to comment Share on other sites More sharing options...
Scythe Posted April 24, 2011 Report Share Posted April 24, 2011 it's probably just a minor driver bug and some dying sensitivity in the receptors beneath the keys, then. Just my 2 cents. Quote Link to comment Share on other sites More sharing options...
