ehall Posted July 26, 2011 Report Share Posted July 26, 2011 My Lenovo laptop will not read CDs (blank or music CDs) but it will read DVDs. My DVD drive is listed in "My Computer" but the CD drive is not there. I have tried the suggestion to delete the upperfilter or the lowerfilter but it they are not listed on my computer.Please help me I need to burn a CD and can't since my laptop won't read CDsThanks Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted July 27, 2011 Report Share Posted July 27, 2011 As different lasers are used to read/write to CD's and DVD's, it would seem that the CD laser has ceased to work. Quote Link to comment Share on other sites More sharing options...
ehall Posted July 27, 2011 Author Report Share Posted July 27, 2011 Then why doesn't the CD drive show up in the My Computer? Quote Link to comment Share on other sites More sharing options...
Boris Posted July 27, 2011 Report Share Posted July 27, 2011 Then why doesn't the CD drive show up in the My Computer?It is the same as the DVD drive. They are not shown separately. Quote Link to comment Share on other sites More sharing options...
ehall Posted July 27, 2011 Author Report Share Posted July 27, 2011 So I have to get a new CD drive? Quote Link to comment Share on other sites More sharing options...
bludgard Posted July 27, 2011 Report Share Posted July 27, 2011 So I have to get a new CD drive?Have you tried to uninstall the device driver via Device Manager and reboot?Or run MS Fixit? Quote Link to comment Share on other sites More sharing options...
ehall Posted July 27, 2011 Author Report Share Posted July 27, 2011 I tried using windows fix it and it said it couldn't fix my problem and I don't know how to do the first thing you said. Quote Link to comment Share on other sites More sharing options...
bludgard Posted July 27, 2011 Report Share Posted July 27, 2011 To access Device Manager: Right click Computer (or My Computer) icon>select Manage>select Device Manager. Under DVD/CD ROM drives click the + sign to expand the tree. Find the device (DVD/CD drive that is installed on your machine) and right click on it>select Uninstall>OK. Reboot to let Windows reinstall the driver. Quote Link to comment Share on other sites More sharing options...
-pops- Posted July 28, 2011 Report Share Posted July 28, 2011 An external CD/DVD writer won't cost very much and can easily be connected to your laptop via USB.I tend always to use a stand alone optical disk writer as I've known several built-in laptop devices die without warning. The construction of laptop optical drives always seems flimsy and delicate to me and getting a bit ancient, clumsy and arthritic (as I am) a more robust device is much better for me.Standalone writers are very easy to use - just plug it in, let Windows find it and download its drivers and away you go. Quote Link to comment Share on other sites More sharing options...
