itsolexpert Posted January 28, 2012 Report Share Posted January 28, 2012 I'm currently using win 7 and it was working well but yesterday suddenly my desktop was disappear and now I'm unable to work. I have many important files which I don't want to loose, Is there a way with I can find my all data without re installing OS. Quote Link to comment Share on other sites More sharing options...
doug Posted January 28, 2012 Report Share Posted January 28, 2012 Try tapping F8 as soon as you switch on. This should then present you with a text based menue with many options. click on the start Windows normally. this should work 9/10 times. If it does make a back-up of everything, especially the valuables files, If you can' get this far then you will need to roll back you OS to an earlier known good configuration. Follow the above F8 method and this time choosed Safe Mode. don't use the Safe Mode with Internet option just yet - that will let you access the internet but is a diverion at the moment. when you get the Safe mode operational go to control panel/System & Security/Back up and restore. Choose the Restore option and select the last known good configuration. Again if successful do a proper backup, Good Luck. Been there myself a few times. Quote Link to comment Share on other sites More sharing options...
AceInfinity Posted January 29, 2012 Report Share Posted January 29, 2012 You're desktop disappeared? Try using Ctrl+Alt+Delete and open up an instance of Task Manager. From here, File > New Task (Run...) > "explorer.exe" > OK. See if that helped. Quote Link to comment Share on other sites More sharing options...
MANEMAN Posted January 29, 2012 Report Share Posted January 29, 2012 No you dont get it do you ? His desktop disappeared, along with his coffee, his false teeth, the whole caboodle. :lol: :lol: Quote Link to comment Share on other sites More sharing options...
bludgard Posted January 29, 2012 Report Share Posted January 29, 2012 I have many important files which I don't want to loose, Is there a way with I can find my all data without re installing OS.Yes; there is, itsolexpert.Boot from a live Linux CD or other bootable device and copy the folder(s)/file(s) over to an external device. Quote Link to comment Share on other sites More sharing options...
