johnoo Posted July 14, 2012 Report Share Posted July 14, 2012 I have created a Backup using the Software within a Seagate External drive.I now wish to delete this from the External drive.If I click right on the Backup folder within the drive & then click Delete, I get a message that says that file names are too long for the Recycle bin & the Back up does not delete.Where am I going wrong? Quote Link to comment Share on other sites More sharing options...
doug Posted July 14, 2012 Report Share Posted July 14, 2012 Before pressing the delete key hold down the shift key and the press delete. Quote Link to comment Share on other sites More sharing options...
johnoo Posted July 14, 2012 Author Report Share Posted July 14, 2012 Doug,Thanks, tried that but I still get the message "The file name you specified is not valid or too long specify different file name", & the file will not delete! Quote Link to comment Share on other sites More sharing options...
doug Posted July 14, 2012 Report Share Posted July 14, 2012 Hmmm that's a puzzle. I find that with W7, and I think previous versions, the delete key sends things straight to the recycle bin. But holding down the shift ket while pressing the delete key "stuff" just gets deleted. You will have to wait for better men, or women (Irene) than me. Orf in the morning for a week so will look in next Sun/Mon to see if you have a solution. Good luck. Quote Link to comment Share on other sites More sharing options...
johnoo Posted July 15, 2012 Author Report Share Posted July 15, 2012 Doug,Thanks have a good holiday, hope I get solution before your return. Quote Link to comment Share on other sites More sharing options...
johnoo Posted July 15, 2012 Author Report Share Posted July 15, 2012 For completeness this is the track of eventsPress Shift/Delete, or right click deleteStarts deleting with box saying "Preparing to Delete"Then get "Confirm Folder delete" message, check YesThen message "Error deleting file or folder" the words being " Message "Cannot delete 2009_04_28 the file name you specified is invalid or too long, Specify a different file name" Quote Link to comment Share on other sites More sharing options...
-pops- Posted July 15, 2012 Report Share Posted July 15, 2012 If there is nothing on the drive that you want to retain, the best thing to do would be a reformat.When I've installed an external drive I always format to remove any included software. It usually isn't very good and not what I've bought the drive for Quote Link to comment Share on other sites More sharing options...
johnoo Posted July 15, 2012 Author Report Share Posted July 15, 2012 Done it!Found the offending file 29_04_28, by using XP search.Drilled down to find it within the External drive folder, deleted it.Thhen went into the "Backup" & deleted, & it worked!But thanks for al of the input, gave me the faith to carry on Quote Link to comment Share on other sites More sharing options...
-pops- Posted July 15, 2012 Report Share Posted July 15, 2012 Excellent! Pleased you are sorted out. Quote Link to comment Share on other sites More sharing options...
