johnoo Posted October 22, 2012 Report Share Posted October 22, 2012 Just purchased one of the above from Amazon UK.It has some "Secure Access" software included.One of the software files, "Run Club San Disk" gave a AVG virus warningAnybody had any experience with this software?Is it worth using/deleting? Quote Link to comment Share on other sites More sharing options...
Boris Posted October 22, 2012 Report Share Posted October 22, 2012 IMHO the Club SanDisk software is only a means for selling you more software from their "partners" (Ebay, Chrome, RoboForm, McAfee + GoToMyPC)http://www.sandisk.com/goto/ClubSanDiskUSB/- you can zap that. The Secure Access software creates a password-protected folder on your SanDisk USB flash drive, so you can "share selected files on your drive without exposing your most sensitive ones". Do you have any need of it ? I just zapped mine :D If for any reason you do develop a use for it in the future, you can download it from :- http://www.sandisk.com/products/software/secureaccess/ Quote Link to comment Share on other sites More sharing options...
johnoo Posted October 22, 2012 Author Report Share Posted October 22, 2012 Boris,I trust you more than the Marketing Dept. of Sandisk, so I will Zap the lot.Many thanks for the advise. Quote Link to comment Share on other sites More sharing options...
andsome Posted October 23, 2012 Report Share Posted October 23, 2012 Just format the drive, that is always my first move. Quote Link to comment Share on other sites More sharing options...
johnoo Posted October 25, 2012 Author Report Share Posted October 25, 2012 What's the difference between just deleting the Programs & Formatting?Also how do I Format? Quote Link to comment Share on other sites More sharing options...
andsome Posted October 25, 2012 Report Share Posted October 25, 2012 What's the difference between just deleting the Programs & Formatting?Also how do I Format?Go to My Computer with the drive plugged in. Right click the icon for it and select Format. This completely reformats the drive as though nothing had ever been on it. Deleting can leave residues. Quote Link to comment Share on other sites More sharing options...
