Johnyboy Posted May 18, 2013 Report Share Posted May 18, 2013 Hey guys. I have recently changed from Windows 7 64bit to Windows xp 32bit and i have had problem with Audio Drivers.I have tried to used Realtek AC'97 Driver (Windows 98/Me/2000/XP2003) and i have had no success it keeps coming up with no Sound Driver installed even tho i have installed this Driver so i tried to look through the Sound Drivers and i found that it said that the driver needed to update and so i tried to up date it and no luck nothing happens so then i tried re-installing the driver multiple times and yet no luck. So is there anyone with a solution to this like a Driver or a tutorial please i really need help... My regards Johnyboy Quote Link to comment Share on other sites More sharing options...
bludgard Posted May 19, 2013 Report Share Posted May 19, 2013 Ol' JohnnyBoy, eh?If the sound card can be identified some progress may be made.Do not want to sound minimalistic, but it may be that simple.... Edit: Wecome.... Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted May 19, 2013 Report Share Posted May 19, 2013 To help you identify your sound card/chip, download Speccy and look under Audio. http://www.filehippo.com/download_speccy/ Quote Link to comment Share on other sites More sharing options...
