johnnybeer Posted August 5, 2013 Report Share Posted August 5, 2013 Trying to get online on my PC after work, no program that required internet connectivity, IE, Chrome, different video games, would work. Check modem and router, rebooted bout a couple times, checked cabling, cables are good. The PC seems to see the network cable when it's hooked up, however I'm still unable to connect to anything requiring the internet. WiFi works, same ethernet cable thats in the PC i removed and plugged into my laptop, with wireless turned off, and can surf fine so it's not a cabling splice or split issue. Device manager states theres no malfunctions with the NIC, have made no changes to firewall settings. Not real sure what else to do. Just get home, yesterday no issues, today can't get online. Running out of ideas to troubleshoot. Any help would be most appreciated.Modem & Router connectivity:Windows XP:TWC provider:No upgrades to software or hardware recently. Was working fine yesterday, today not so much. Quote Link to comment Share on other sites More sharing options...
Boris Posted August 6, 2013 Report Share Posted August 6, 2013 Possibly a registry or DNS problem ? You could try using this :- http://www.majorgeeks.com/files/details/complete_internet_repair.html I have found it to be good for fixing mysterious connection problems - provided you use it as it says! Quote Link to comment Share on other sites More sharing options...
