andsome Posted February 8, 2014 Report Share Posted February 8, 2014 I have a DVD that I copied from one that my Granddaughter had made of her doing a bungee jump over Victoria falls. It plays perfectly on the computer in Windows Media player, but will not play on our DVD player downstairs. Can anyone suggest a free program please to convert the files so that I can burn a copy to play on a Panasonic DMR-EX768EB, DVD player. Quote Link to comment Share on other sites More sharing options...
Belatucadrus Posted February 8, 2014 Report Share Posted February 8, 2014 Try Ashampoo free I've not used this exact version but my 2010 version includes the options to burn DVDs or CDs that will play on a DVD player, presumably this one still has those features. Quote Link to comment Share on other sites More sharing options...
andsome Posted February 8, 2014 Author Report Share Posted February 8, 2014 Many thanks for the reply. I have downloaded and installed it, and will try it later when I have finished a little job I am doing now. I will let you know how I get on. Quote Link to comment Share on other sites More sharing options...
Boris Posted February 8, 2014 Report Share Posted February 8, 2014 Keith What format are the files on the DVD which plays OK in Windows Media Player ? Ashampoo won't convert them for you - it is primarily a burning programme. Quote Link to comment Share on other sites More sharing options...
Belatucadrus Posted February 8, 2014 Report Share Posted February 8, 2014 If you do find you need a video file converter as-well there are a few here Quote Link to comment Share on other sites More sharing options...
andsome Posted February 9, 2014 Author Report Share Posted February 9, 2014 Thanks folks. I used easy dvd converter. Nero did not want to know about burning it, but ashampoo did the job. Quote Link to comment Share on other sites More sharing options...
