cinque8 Posted September 26, 2014 Report Share Posted September 26, 2014 Hi, I have a HP computer running Windows Vista. I have 3 video players on my computer: Realplayer, Windows Media Player, and VideoBuzz. My video players will play videos that I have stored on my hardrive with no problem. But when I insert a DVD into my DVD player I get and error message that says that the DVD cannot be played and that I should try to adjust the display settings in the Control Panel. I can't find Display Settings in the control panel. Also I noticed that when I insert the DVD into the drive, the light on the outside of the drive does not come on.Does anyone have any suggestions? Thanks! Quote Link to comment Share on other sites More sharing options...
Belatucadrus Posted September 26, 2014 Report Share Posted September 26, 2014 Sounds like a hardware issue, try running a cleaning CD/DVD, but I have to say my success with getting DVD players back on their feet once they begin to fail is limited. You may end up having to get a new DVD unit fitted. Quote Link to comment Share on other sites More sharing options...
cinque8 Posted September 27, 2014 Author Report Share Posted September 27, 2014 Thanks for the info Belatucadrus Quote Link to comment Share on other sites More sharing options...
Boris Posted September 27, 2014 Report Share Posted September 27, 2014 Also check that the cable connecting the DVD unit to the motherboard hasn't become loose/detached Quote Link to comment Share on other sites More sharing options...
cinque8 Posted September 27, 2014 Author Report Share Posted September 27, 2014 Thanks Boris, I will check the cable. Quote Link to comment Share on other sites More sharing options...
