johnoo Posted September 29, 2015 Report Share Posted September 29, 2015 I have got this message on my Lenovo Computer Solution CenterIt says it's due to code 43What should I do? Quote Link to comment Share on other sites More sharing options...
Boris Posted September 29, 2015 Report Share Posted September 29, 2015 Have you got the latest Intel chipset drivers installed on this machine ? Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted September 29, 2015 Report Share Posted September 29, 2015 And what is the driver version of your Intel Management Engine Interface? The current version is 11.0.0.1166. Quote Link to comment Share on other sites More sharing options...
johnoo Posted September 30, 2015 Author Report Share Posted September 30, 2015 Going into the Management Engine I/Face details it says the current driver version is 9.5.10.1658.But I'm concerned because I recently downloaded a revised BIOS Program, version 1.70 which gave me problems & a IBM engineer came out & fitted a new Motherboard, so I would have thought that it had the latest versions of chips etc. Quote Link to comment Share on other sites More sharing options...
Boris Posted September 30, 2015 Report Share Posted September 30, 2015 Hardware (with its BIOS) and drivers are quite different.The new board needs the Intel Management Engine Interface driver updated to the version Pat quoted. Quote Link to comment Share on other sites More sharing options...
johnoo Posted September 30, 2015 Author Report Share Posted September 30, 2015 Thanks, I've now tried to update.Went into the Driver details/Update Driver/Search Automatically, got message to say that "Current Driver is up to date"Now I'm lost! Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted October 2, 2015 Report Share Posted October 2, 2015 First thing I would try: delete the driver for the Intel Management Engine Interface, restart Windows and see what happens. If that does not fix the problem:what is your Windows version?what is that new motherboard?do you have the Chipset Identification Utility installed? Quote Link to comment Share on other sites More sharing options...
johnoo Posted October 2, 2015 Author Report Share Posted October 2, 2015 Pat,I was scared to do it, but took the risk & deleted the Driver.& restarted windows, version 8.1.In the Devise manager, the "Management Engine I/face" now shows not to have a problem.But the driver version is Version 7.0.0.1144 dated 19/10/2010.Went in to update Driver & told "Latest version installed" However now found that a newer Driver version was in the Solution Center waiting to be installed, version 9.5.10.1658 so I have installed this. So why has an older driver version been installed but now told this is the latest?Also has it cured the problem? Also please advise how I can find the Motherboard type?, I've looked on the specification within "Solution Center" & can't find it Quote Link to comment Share on other sites More sharing options...
Boris Posted October 2, 2015 Report Share Posted October 2, 2015 Motherboard type ?Speccy tells you everything :- https://www.piriform.com/speccy/download/standard Quote Link to comment Share on other sites More sharing options...
johnoo Posted October 2, 2015 Author Report Share Posted October 2, 2015 Data re Motherboard from SpecyManufacture LenovoVersion Lenovo ProductChipset IntelChipset Model Ivy BridgeChipset Revision 09Southbridge Model H61Southbridge Rev. B2 Quote Link to comment Share on other sites More sharing options...
Boris Posted October 2, 2015 Report Share Posted October 2, 2015 Unfortunately, you don't get the best info on a board when it is a laptop from one of the main manufacturers - the boards are normally bespoke - so you can't do much with them :( Fora desktop with a normal board you get better info e.g. Manufacturer FoxconnModel G31MX Series (Socket 775)Version OEMChipset Vendor IntelChipset Model P35/G33/G31Chipset Revision 10Southbridge Vendor IntelSouthbridge Model 82801GB (ICH7/R)Southbridge Revision A1 Why did you want to know the details of yours for anyway ? Quote Link to comment Share on other sites More sharing options...
johnoo Posted October 2, 2015 Author Report Share Posted October 2, 2015 Point 1 its not a laptop but a Lenovo Edge 72 tower.2 Wanted the information because Pat asked the question in a earlier post.Assume it's now irrelevant as the problem seems to be solved by deleting the driver & restarting Quote Link to comment Share on other sites More sharing options...
Boris Posted October 2, 2015 Report Share Posted October 2, 2015 Ah ! it is one of these :- http://shop.lenovo.com/gb/en/desktops/thinkcentre/edge-series-towers/edge-72/#tab-tech_specs My comments re. "laptop" above apply exactly the same to mass produced desktops - which have their own "OEM branded" boards built for them by makers such as Foxconn. It makes ugrading them with faster processors etc. just a tad more difficult :). Luckily your model does list the range of CPUs that it will take. Quote Link to comment Share on other sites More sharing options...
johnoo Posted October 2, 2015 Author Report Share Posted October 2, 2015 Think this may have gone of track.The problem was with the MEI being disabled code 43.Using Pats idea I have now solved this, I hope permanentlyI would love to know why it went "bad" in the first place, but perhaps should consider myself lucky that this forum exists to give help in situations like this Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted October 4, 2015 Report Share Posted October 4, 2015 I would love to know why it went "bad" in the first place, but perhaps should consider myself lucky that this forum exists to give help in situations like this Sorry, I don't know "why". I had a very similar problem with a different device after upgrading to Windows 10. I deleted the driver, restarted Windows, and voilà: it was fixed. The same thing (same device) happened again this week, and I used the same procedure to fix it again. P.S. if you are curious why there are different "newest" driver versions: there is always the one from the manufacturer (usually higher), and there is the generic one assigned by Microsoft to Windows. I personally like to have the newest "newest" driver installed... Quote Link to comment Share on other sites More sharing options...
johnoo Posted October 4, 2015 Author Report Share Posted October 4, 2015 Interesting, wonder what caused it, especially as it was on the same devise.Would love to know, any answers? Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted October 4, 2015 Report Share Posted October 4, 2015 Possible: incorrect Windows shutdown, problem during startup, ...? Quote Link to comment Share on other sites More sharing options...
johnoo Posted October 5, 2015 Author Report Share Posted October 5, 2015 Need to be more of an expert than I am to even give out ideas! Quote Link to comment Share on other sites More sharing options...
rosietesmen Posted April 11, 2016 Report Share Posted April 11, 2016 In general, the newer the board/chipset (Intel 7 or 8 series), the more you need the IME software. It's not a Gigabyte driver, it is from Intel and does many underlying things that are difficult to explain. All of the chipset's features may not work until IME is installed. The Device Manager unknown device entry is a sign that IME is not installed. Quote Link to comment Share on other sites More sharing options...
bludgard Posted May 22, 2016 Report Share Posted May 22, 2016 A bit late in the game, but Lenovo System Update utility takes care of things pretty decently on their products. It offers drivers, firmware and other packages that one may wish to install. We own a few ThinkPads and use this method 95% of the time to update our products. Quote Link to comment Share on other sites More sharing options...
