moon Posted November 14, 2003 Author Report Share Posted November 14, 2003 Nope. I can't envisage it coming off unless I can ever afford a 64bit AMD cpu and the motherboard will run one.Thanks for confirmation, Lucky. Should I polish the core with anything first ? Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted November 14, 2003 Report Share Posted November 14, 2003 no just fit the bloody thing :D Quote Link to comment Share on other sites More sharing options...
moon Posted November 14, 2003 Author Report Share Posted November 14, 2003 LOL ! Later. :D Quote Link to comment Share on other sites More sharing options...
Guest Grim Reaper Posted November 14, 2003 Report Share Posted November 14, 2003 Should I polish the core with anything first ?well, perhaps one should get some mr sheen and a metal scourer........... Quote Link to comment Share on other sites More sharing options...
Guest nellie2 Posted November 14, 2003 Report Share Posted November 14, 2003 well, perhaps one should get some mr sheen and a metal scourer...........:o OMG...... tell me you are joking!!!! ..... you don't really polish them do you?? :blink: Quote Link to comment Share on other sites More sharing options...
moon Posted November 14, 2003 Author Report Share Posted November 14, 2003 How long should I boil my motherboard for ? :D Quote Link to comment Share on other sites More sharing options...
Boris Posted November 14, 2003 Report Share Posted November 14, 2003 moonIf you want an old-timers advice on the best way to cook a motherboard ?I would definitely not boil it !They give far better results - if fried :D Quote Link to comment Share on other sites More sharing options...
