Rubbish freeware problem
I downloaded an app. to hide sensitive folders, ran it, hid a folder and the damn app. wont run again. Tried everything. I'll just have to write the folder off ( backup somewhere ) Anyway, I've deleted all references to the app. except I'm stuck with one .dll in the Windows folder which I can't delete or rename . Message is ' Cannot delete or rename. This file is in use by Windows' How do I get rid of the bugger, and if I do, will I be able to see my folder again ?
How would I tell, Grim ? There's nothing in its 'properties' other than read-only/archive/hidden. I've unchecked all those but the 'system' box is locked.
It's Akas, -pops-. I should have smelled a rat by the name. :D After you've hidden a file the only window that will open is the 'Buy the Pro version' one. I guess they rely on mugs to go for that in order to make their folders visible again. Neat but nasty.
EDIT : Grim, the entire disk has 'sharing' enabled.
moon
Your invisible folders is always hidden, including Safe mode, MS-DOS and even when Hide Folder is not running.
Don't think DOS is the answer :( .
I presume it didn't uninstall properly ?
Have you tried re-installing it to see if it'll run once again ?
Have you had a look in the help file ? http://www.apihook.com/hidefolder/AKASShp.chm
Have you tried emailing them ? - [email protected]
Thanks chaps.
Your penultimate post first, boris, it ran, hid my folder and then vanished. Only the 'buy me' window reappears. As there is no programme to access there are no tools available and the 'help' link is therefore useless. It won't reinstall. Message is ' Uninstall previous versions first' I emailed them beore posting here. No reply.
The AkasHook.dll must be one with the info. which keeps my folder hidden and it must be booting because I can't delete it after a reboot ( nor in safemode) C-A-D does not show it as a running app. but it must be a running process.
I'll try getting at it with DOS ( bugger) a bit later if anyone is around.
Here ya go chaps. Anyone make sense of this lot for me ?
Logfile of HijackThis v1.97.2
Scan saved at 18:46:49, on 12/12/03
Platform: Windows 98 SE (Win9x 4.10.2222A)
MSIE: Internet Explorer v6.00 (6.00.2600.0000)
Running processes:
C:\WINDOWS\SYSTEM\KERNEL32.DLL
C:\WINDOWS\SYSTEM\MSGSRV32.EXE
C:\WINDOWS\SYSTEM\MPREXE.EXE
C:\PROGRAM FILES\GRISOFT\AVG6\AVGSERV9.EXE
C:\PROGRAM FILES\AGNITUM\OUTPOST FIREWALL\OUTPOST.EXE
C:\WINDOWS\SYSTEM\mmtask.tsk
C:\WINDOWS\EXPLORER.EXE
C:\WINDOWS\SYSTEM\SYSTRAY.EXE
C:\PROGRAM FILES\GRISOFT\AVG6\AVGCC32.EXE
C:\WINDOWS\STARTUPMONITOR.EXE
C:\WINDOWS\SYSTEM\WMIEXE.EXE
C:\WINDOWS\SYSTEM\SPOOL32.EXE
C:\PROGRAM FILES\INTERNET EXPLORER\IEXPLORE.EXE
C:\WINDOWS\NOTEPAD.EXE
C:\UNZIPPED\HIJACKTHIS\HIJACKTHIS.EXE
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://pcpitstop.ibforums.com/
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Local Page =
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page =
O2 - BHO: (no name) - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\PROGRAM FILES\ADOBE\ACROBAT 5.0\READER\ACTIVEX\ACROIEHELPER.OCX
O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\SPYBOT~1.1\SDHELPER.DLL
O2 - BHO: (no name) - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar1.dll
O3 - Toolbar: (no name) - {62999427-33FC-4baf-9C9C-BCE6BD127F08} - (no file)
O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar1.dll
O4 - HKLM\..\Run: [scanRegistry] C:\WINDOWS\scanregw.exe /autorun
O4 - HKLM\..\Run: [systemTray] SysTray.Exe
O4 - HKLM\..\Run: [AVG_CC] C:\PROGRAM FILES\GRISOFT\AVG6\avgcc32.exe /startup
O4 - HKLM\..\Run: [Run StartupMonitor] StartupMonitor.exe
O4 - HKLM\..\Run: [LoadPowerProfile] Rundll32.exe powrprof.dll,LoadCurrentPwrScheme
O4 - HKLM\..\Run: [Outpost Firewall] C:\PROGRAM FILES\AGNITUM\OUTPOST FIREWALL\OUTPOST.EXE /waitservice
O4 - HKLM\..\RunServices: [Avgserv9.exe] C:\PROGRA~1\GRISOFT\AVG6\Avgserv9.exe
O4 - HKLM\..\RunServices: [Outpost Firewall] C:\PROGRAM FILES\AGNITUM\OUTPOST FIREWALL\OUTPOST.EXE /service
O6 - HKCU\Software\Policies\Microsoft\Internet Explorer\Restrictions present
O6 - HKCU\Software\Policies\Microsoft\Internet Explorer\Control Panel present
O8 - Extra context menu item: &Download with &DAP - C:\PROGRA~1\DAP\dapextie.htm
O8 - Extra context menu item: Download &all with DAP - C:\PROGRA~1\DAP\dapextie2.htm
O8 - Extra context menu item: &Google Search - res://C:\PROGRAM FILES\GOOGLE\GOOGLETOOLBAR1.DLL/cmsearch.html
O8 - Extra context menu item: Cac&hed Snapshot of Page - res://C:\PROGRAM FILES\GOOGLE\GOOGLETOOLBAR1.DLL/cmcache.html
O8 - Extra context menu item: Si&milar Pages - res://C:\PROGRAM FILES\GOOGLE\GOOGLETOOLBAR1.DLL/cmsimilar.html
O8 - Extra context menu item: Backward &Links - res://C:\PROGRAM FILES\GOOGLE\GOOGLETOOLBAR1.DLL/cmbacklinks.html
O8 - Extra context menu item: Translate into English - res://C:\PROGRAM FILES\GOOGLE\GOOGLETOOLBAR1.DLL/cmtrans.html
O8 - Extra context menu item: Download using Download &Express - file://C:\Program Files\Download Express\Add_Url.htm
O9 - Extra button: Related (HKLM)
O9 - Extra 'Tools' menuitem: Show &Related Links (HKLM)
O9 - Extra 'Tools' menuitem: Sun Java Console (HKLM)
O9 - Extra button: Trashcan (HKCU)
O9 - Extra 'Tools' menuitem: Show Trashcan (HKCU)
O12 - Plugin for .pdf: C:\PROGRA~1\INTERN~1\PLUGINS\nppdf32.dll
O12 - Plugin for .spop: C:\PROGRA~1\INTERN~1\Plugins\NPDocBox.dll
O12 - Plugin for .bcf: C:\PROGRA~1\INTERN~1\Plugins\NPBelv32.dll
O16 - DPF: Win32 Classes -
O16 - DPF: {0E5F0222-96B9-11D3-8997-00104BD12D94} (PCPitstop Utility) - http://www.pcpitstop.com/pcpitstop/PCPitStop.CAB
O16 - DPF: {AE9DCB17-F804-11D2-A44A-0020182C1446} (IntraLaunch.MainControl) - file://E:\SuperCD\IntraLaunch.CAB
O16 - DPF: {CC05BC12-2AA2-4AC7-AC81-0E40F83B1ADF} (Live365Player Class) - http://www.live365.com/players/play365.cab
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://download.macromedia.com/pub/shockwa...ash/swflash.cab
O16 - DPF: {9732FB42-C321-11D1-836F-00A0C993F125} (mhLabel Class) - http://www.pcpitstop.com/mhLbl.cab
O17 - HKLM\System\CCS\Services\VxD\MSTCP: Domain = Censored
O17 - HKLM\System\CCS\Services\VxD\MSTCP: NameServer = Censored
Can't see anything in there regarding AkasHook.dll, moon,
unless it is linked to
as you have Download express, and, if you no longer use DAP you might like to get rid of
these restrictions
I assume you have set using Spybot S & D if not have HJT fix them
Close all browser and explorer windows then hit the 'fix checked' button
