Guest nellie2 Posted December 20, 2003 Report Share Posted December 20, 2003 This NTFS reader fits onto a FreeDOS bootable floppy which means that, should your NTFS based Windows system become terminally corrupted, you can still access your disks. It even includes a file search and copy utility. Can be saved and run from bootable floppy (download boot disk image) Displays complete physical and logical drive information Supports IDE / ATA / SCSI drives Supports large (more than 8GB) Hard Drive Supports NTFS, NTFS5 file systems for reading Supports FAT12, FAT16, FAT32 file systems for data writing Supports compressed and fragmented files on NTFS Supports partitions created in MS-DOS, Windows XP.2000.NT.ME.98.95 Displays non-english and long file names Ability to preview file(s)/folder(s) before copying Supports search by file name or mask Disk Viewer displays content of the file in Hex/Text modeGet it here Quote Link to comment Share on other sites More sharing options...
-pops- Posted December 20, 2003 Report Share Posted December 20, 2003 Definitely one to go in the "Break Glass in Emergency" folder.Could be very useful but I hope never to have to use it.Thanks Nellie Quote Link to comment Share on other sites More sharing options...
Chris Posted December 20, 2003 Report Share Posted December 20, 2003 Hmm but where do you copy to? Quote Link to comment Share on other sites More sharing options...
Guest spikeychris Posted December 20, 2003 Report Share Posted December 20, 2003 Keep these priceless links coming Nel, worth its weight in gold.Powerless you would copy to \Windows. Quote Link to comment Share on other sites More sharing options...
mark2 Posted December 21, 2003 Report Share Posted December 21, 2003 Further disc utilities, all on one bootable cd Ultimate boot CD Quote Link to comment Share on other sites More sharing options...
Chris Posted December 21, 2003 Report Share Posted December 21, 2003 Keep these priceless links coming Nel, worth its weight in gold.Powerless you would copy to \Windows.OK i am soooooooooooooo missing something here.You can copy files to /Windows but if your drive is kaput or you cannot enter Windows how do you then get your files?If you have another partition then ok. But if you do not... Quote Link to comment Share on other sites More sharing options...
