AlanHo Posted January 17, 2004 Report Share Posted January 17, 2004 My LG DVD burner has started playing up. When copying large files or a large number of files such as when doing a data back-up it suddenly stops recording and throws up an error message .........Data read or write error (Cyclic Redundancy Check). This seems to happen at random times - sometimes early in the recording and others when near the end.I have no idea what a cyclic redundancy check is or what causes the error.The problem has occurred since a recent reinstall of Windows XP - the burner was well behaved beforehand.I have tried using device manager to uninstall the DVD and reinstall it - but the problem remains.I have done a Windows XP repair. Still no luck.I have uninstalled and reinstalled the LG DVD RAM Driver - but it made no difference.Praying and/or cussing did not do the trick - I have not yet resorted to a physical attack on the machine but am getting close to it.The problem occurs with DVD-RAM and DVD-RW media - I have not tried CD-R/RW or DVD-R yet but feel it will be the same.Any ideas ? :wallbash: Quote Link to comment Share on other sites More sharing options...
bvw Posted January 17, 2004 Report Share Posted January 17, 2004 The disk may be faulty or scratched, also try burning at a lower speed. Quote Link to comment Share on other sites More sharing options...
-pops- Posted January 17, 2004 Report Share Posted January 17, 2004 DVD burners are very fussy about the media they will write to. Have you changed the brand/type of disk? Quote Link to comment Share on other sites More sharing options...
AlanHo Posted January 17, 2004 Author Report Share Posted January 17, 2004 I am using the same discs I have always used for my backups. TDK brand which worked flawlessly before the Windows reinstall and are definitely not scratched. I also ran a full check disc on the media and found no errors.I can generally drag and drop files to the DVD burner one at a time and get no problems - it is when I drag and drop a large file (say 130 Mb) or when I use my back-up software to back up my data (amounting to 2.4GB and 5500 files) that the problem rears its ugly head - but not every time.I cannot burn DVD-RAM discs at a lower speed because they behave like a hard disc - you can drag and drop files to them using Windows Explorer or any other software and do not need any special burning software. Frankly - I don't know why this format is not more popular for data storage - the media is more robust and can be written to and deleted 100 times more than DVD-RW or DVD+RW. In my opinion an ideal back-up medium. (When it works of course)I forget to mention in my original posting that I also downloaded and installed the latest LG DVD firmware.I also tried uninstalling the DVD-RW burner software provided by LG (B's Clip etc) and installed Pinnacle Instant CD+DVD burning software in its place - but still no luck. It all seems to point to the link between the operating system and the burner - or am I being too simplistic in my ignorance. Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted January 17, 2004 Report Share Posted January 17, 2004 try another ASPI Driver or try DVD Decrypter both available here http://www.dvddecrypter.com/download.aspCyclic Redundancy Check (CRC)A method for computing a signature of a sequence of bytes used to detect the presence of errors in the data. Quote Link to comment Share on other sites More sharing options...
trackrat Posted January 17, 2004 Report Share Posted January 17, 2004 This site explains CRC.http://www2.rad.com/networks/1994/err_con/crc.htm Quote Link to comment Share on other sites More sharing options...
AlanHo Posted January 17, 2004 Author Report Share Posted January 17, 2004 trackratWOW - now all is revealed - but what does it mean in practical terms. I am getting a computer freeze due to a CRC - but what causes it and how do I cure it ? The info you provided is fascinating - but with my limited knowledge of computers it is the equivalent of giving an octopus a set of bagpipes. He won't know what to do with it - but eventually will work it out - and it will not be to play a tune.From the information you provided ot appears that the computer chokes on a validity test applied by a CRC test - some complex mathematical formula decided that the copy process has had enough and will retire from service. But why, how and when ?I am not all that au fait with the technicalities of computers - I would class mysel as an advanced user but very limited on the technical side. Hence I have a rough understanding of the info you provided - but don't know what to do with it. Quote Link to comment Share on other sites More sharing options...
Chris Posted January 17, 2004 Report Share Posted January 17, 2004 My initial and last thinking is that DVD laser, is buggered somehow. Quote Link to comment Share on other sites More sharing options...
-pops- Posted January 18, 2004 Report Share Posted January 18, 2004 I forget to mention in my original posting that I also downloaded and installed the latest LG DVD firmware.I am not saying that this is tha cause of your woes but, it may be.I am a great one for the "if it ain't broke, don't fix it" philosophy. I would never contemplate flashing my BIOS, firmware upgrading anything at all unless it was absolutely necessary - indicated by the equipment in question was not working. Quote Link to comment Share on other sites More sharing options...
AlanHo Posted January 18, 2004 Author Report Share Posted January 18, 2004 PopsI take your point - but I only tried the firmware update after all else had failed.Taking my weekly back-up today was a real chore. I had to manually copy small blocks of files - it took me nearly four hours. Normally I just click on the back-up icon and retire to the conservatory for an afternoon beer or G&T for an hour or so whilst the computer does its stuff.I have now sent an Email to LG support to see if they can help. Quote Link to comment Share on other sites More sharing options...
