Guest Blink_182_fan Posted March 2, 2004 Report Share Posted March 2, 2004 As some of you know my computer is not working and when i open folders nothing appers but the files are actually there. i finally gave up trying to fix it as mark 2 tryied to fix it but there was no way eexcept formating which i do not want to do because of my brothers important A/S level course work files which i will back up eventually.But back to the point... my computer is running out of space quickly and i cannot get into add/remove programs and i was wondering if there was a comand prompt for it i was going to google it but i decided to see if anyone here could easily tell me if there was Quote Link to comment Share on other sites More sharing options...
nellie2 Posted March 2, 2004 Report Share Posted March 2, 2004 Windows 2000/XPClick Start. Click Run. Type in cmd in the Open field and click OK. That will open a black command prompt window. Click into the black window so you can type commands in.TipsYou can see a list of all the commands usable in a command line by typing in Help and pressing the Enter key on your keyboard. You can view information page by page by adding a space and then | more to the end of most commands. The | symbol is called a Pipe and is generated by pressing Shift and \ Every command you enter in a command line should be followed by pressing the Enter key on your keyboard. You can make the command window full screen or windowed by using the key combination ALT and ENTER.You can close the command prompt by typing in Exit.scource Quote Link to comment Share on other sites More sharing options...
Boris Posted March 2, 2004 Report Share Posted March 2, 2004 Easy fix ? :o Download TweakAll3 from :-http://www.codeforge.co.uk/files/tweakall3fullsetup.exeInstall it.Under the General tab is an "Add/Remove Programs option" - just like in Control Panel. :DJust remove stuff from the "Visible" section ! Quote Link to comment Share on other sites More sharing options...
Guest Blink_182_fan Posted March 2, 2004 Report Share Posted March 2, 2004 thanks nellie and boris and nellie i tryed tyoing in cmd but no black command propt bar opened Quote Link to comment Share on other sites More sharing options...
Guest Blink_182_fan Posted March 2, 2004 Report Share Posted March 2, 2004 i still need a comand prompt because i wanted to repair a program which i was able to do with add/remove programs but i couldnt find it in tweakall3 Quote Link to comment Share on other sites More sharing options...
nellie2 Posted March 2, 2004 Report Share Posted March 2, 2004 You going to Start > run ? see pic Quote Link to comment Share on other sites More sharing options...
Boris Posted March 2, 2004 Report Share Posted March 2, 2004 You didn't mention repairing ! :o - only making more room on your H/D ! Quote Link to comment Share on other sites More sharing options...
Guest Blink_182_fan Posted March 2, 2004 Report Share Posted March 2, 2004 uyes but this comes up Quote Link to comment Share on other sites More sharing options...
nellie2 Posted March 2, 2004 Report Share Posted March 2, 2004 what version of windows are you using again??? Quote Link to comment Share on other sites More sharing options...
Boris Posted March 2, 2004 Report Share Posted March 2, 2004 cmd.exe should be in C:\WINDOWS\system32 - have you got one there ? Quote Link to comment Share on other sites More sharing options...
nellie2 Posted March 2, 2004 Report Share Posted March 2, 2004 It's windows ME isn't it??start>programs>accesories>command prompt Sorry.... I was giving you the XP access to command prompt!!! :huh: Quote Link to comment Share on other sites More sharing options...
Guest Blink_182_fan Posted March 2, 2004 Report Share Posted March 2, 2004 i have windows me and im sorry boris Quote Link to comment Share on other sites More sharing options...
Guest Blink_182_fan Posted March 2, 2004 Report Share Posted March 2, 2004 nope not there this is all i have in accesories Quote Link to comment Share on other sites More sharing options...
nellie2 Posted March 2, 2004 Report Share Posted March 2, 2004 MS Dos Prompt is another way of saying Command prompt!!!! ;) Quote Link to comment Share on other sites More sharing options...
Guest Blink_182_fan Posted March 2, 2004 Report Share Posted March 2, 2004 o rite sorry Quote Link to comment Share on other sites More sharing options...
Guest Blink_182_fan Posted March 2, 2004 Report Share Posted March 2, 2004 nope i typed in cmd came up bad command then i typed in help but i was a bad command Quote Link to comment Share on other sites More sharing options...
nellie2 Posted March 2, 2004 Report Share Posted March 2, 2004 blink I have just noticed something.......... Purity scan is bad.... adaware will remove it, just make sure you update it before you run it Quote Link to comment Share on other sites More sharing options...
Boris Posted March 2, 2004 Report Share Posted March 2, 2004 Do a search for cmd.exe - is it still there ? Quote Link to comment Share on other sites More sharing options...
nellie2 Posted March 2, 2004 Report Share Posted March 2, 2004 I found a few ME command prompts here... but I just did a google for themhttp://support.microsoft.com/default.aspx?...4&Product=winme Quote Link to comment Share on other sites More sharing options...
Agent Smith Posted March 3, 2004 Report Share Posted March 3, 2004 Hi All,For Win 95, 98 and Me you need to type "command" (no quotes) in the run box. Cmd is for NT, 2K and XP.Mr. M. Quote Link to comment Share on other sites More sharing options...
Boris Posted March 3, 2004 Report Share Posted March 3, 2004 Totally forgotten since I last used ME 4 months back ! :blush: Quote Link to comment Share on other sites More sharing options...
Chris Posted March 3, 2004 Report Share Posted March 3, 2004 Start, Run, Type: appwizClick OK.If the above does not work type:appwiz.cplClick OK.If the above does not work go to Search and enter the keyword:*.cplStart the search and click the found files and one of them should popup the add/remove. (assuming search works) Quote Link to comment Share on other sites More sharing options...
Guest Blink_182_fan Posted March 3, 2004 Report Share Posted March 3, 2004 thanks all ive now got it to workBlink_182_fan Quote Link to comment Share on other sites More sharing options...
Chris Posted March 3, 2004 Report Share Posted March 3, 2004 How? Quote Link to comment Share on other sites More sharing options...
Guest Blink_182_fan Posted March 3, 2004 Report Share Posted March 3, 2004 i went to start>run and typed in appwiz.cpl Quote Link to comment Share on other sites More sharing options...
