CD/RW problem
My 3 month old Sony CRX225E 52x24x32 CD/RW has just stopped in the middle of burning a CD. It still seems to read CDs OK. I'm using Nero 6.3.1.6. and 48x CD-Rs but only burning at 16x.
Event Viewer reports lots of :-
The device, \Device\CdRom0, has a bad block.
messages every 7 seconds.
The Help + Support Center gives the following "help"
Explanation
The device has a bad block of memory, which Windows attempted to read. The data might be missing or corrupted.
User Action
Do one or all of the following:
Retry the operation.
Clean the physical hard drive.
Use newer media.
I've tried a CD Lens Cleaner on it - nothing.
Any advice ???????
Guest ellas
as powerless says its bust,what does it say in device manger under IDE controllers,if the cdrw is set to PIO mode and not DMA its prob dodgy like my cdrw was.
Boris, what brand of discs are you using? It is possible that the drive just dosn't like them. You could try a different brand, but I am thinking that powerless is probably correct  :(  I think that the drive needs to be replaced under warranty.
Mr. M.
"This device is working properly." + see attached.
I'm using some e-Proformance 48xCD-Rs that have worked perfectly OK with it before ( - it was burning them OK last night ! )
Very interestingly, it still writes files to multi-session CDs and it's just written a complete image file OK from the H/D (both using the same e-Proformance CD-Rs) :blink:
Warranty replacement if required is a bit tricky - I didn't actually buy it (no receipt) it was made Oct 2003 ? I think (according to the sticker).
It was given me as a "thankyou" by someone when I major upgraded their PC (they had received it as an unwanted Xmas present but they didn't want it as they had already bought a DVD writer for the upgrade). They've since moved away unfortunately !
Is it something Nero related ?????
Correction - just written another completely different image file OK from the H/D
Not tried that !
Mrs Boris has had a spring clean and I don't know where she has "tidied" my bulk stock of Cd-Rs away to ! :D
My "working" stock has run out !
When she returns - I'll give it a go !
Just been having a look on their site
Not the easiest to navigate :(
Is this any help http://www.sonyisstorage.com/
Email Support
For e-mail support on tape storage, file server, back up appliance or storstation devices please contact: [email protected]
For e-mail support on on all other Sony SES products please contact: [email protected]
did you try the built in xp writer boris.
ellas - Nothing seems to work ? Also tried 3 different Nero versions tonight.
I've tried another CD/RW as well which i think was OK and that has similar problems.
Starting to think that it may be something else ? - but what ??? :blink:
Will change the IDE cable and try yet another CD/RW in the morning.
