mark2 Posted September 16, 2004 Report Share Posted September 16, 2004 to use the spill chucker doug , r/click in your text and select check spelling Quote Link to comment Share on other sites More sharing options...
D4\/!d Posted September 16, 2004 Report Share Posted September 16, 2004 back again Mark2, right, turned off the FF popup stopper, tried again, still get the blank tab. It doesn't seem to be behaving does it. Mark, I'm happy to leave it there, (unless you are one of these characters who * won't be beaten*) Quote Link to comment Share on other sites More sharing options...
doug Posted September 16, 2004 Report Share Posted September 16, 2004 guve this a goRight clicked on it but no sign of spell check facility Quote Link to comment Share on other sites More sharing options...
mark2 Posted September 16, 2004 Report Share Posted September 16, 2004 I don't like to be beaten, but I should have an early start tomorrow, however , go to tools > extensions see if it is in there ?If not , try the install direct from the website once more, see if anything happens now the popper is offit's beginning to annoy me now :D Quote Link to comment Share on other sites More sharing options...
D4\/!d Posted September 16, 2004 Report Share Posted September 16, 2004 right, give me a few minutes... Quote Link to comment Share on other sites More sharing options...
doug Posted September 16, 2004 Report Share Posted September 16, 2004 Tools/Extensions just produces an empty box with an active update button. This Box had cropped up before after the installation. Clicking on the update button says Up dated. I think. let me post this and I'll check it again.That was correct no updates available. I note thought that the pop-up stopper comes up eachtime I click on Extensions so have to hold down ctrl. Quote Link to comment Share on other sites More sharing options...
D4\/!d Posted September 16, 2004 Report Share Posted September 16, 2004 Havng difficulty downloading it Get the please wait message and then nothing further ...didn't need long to see that it behaved the same as it does for doug.Give it a rest now Mark2, coz I think you need to turn in if you've got to get up early. ;) night, night. ;) Quote Link to comment Share on other sites More sharing options...
doug Posted September 16, 2004 Report Share Posted September 16, 2004 Ditto, G'night mark Quote Link to comment Share on other sites More sharing options...
mark2 Posted September 16, 2004 Report Share Posted September 16, 2004 just had a look at the 'bugs' page noticed Before reporting any bug - especially those that may be related to the interaction of SpellBound with another extension - I ask that you first verify it still exists when using SpellBound without any other extensions. This can be done by creating a new profile and installing SpellBound again or by disabling all other extensions in the Extension Manager though this second method is not as reliable as the first.and also Firefox 0.9 or aboveThis extension currently only works with Firefox 0.9 or above. If you aren't running Firefox 0.9 or above and decide to install it (Firefox product page) please read the release notes first... especially the part where it states "NOTE - Do not install Firefox over the top of another Firefox installation" if you are a Windows user.perhaps uninstall firefox, delete the firefox folder in program files and reinstall then try installing spell boundDon't all give up now :D , we'll get there somehow Quote Link to comment Share on other sites More sharing options...
doug Posted September 16, 2004 Report Share Posted September 16, 2004 Hmmm. Will give that a go tomorrow. NOW GO TO BED. G'night Quote Link to comment Share on other sites More sharing options...
mark2 Posted September 16, 2004 Report Share Posted September 16, 2004 I've just topped up my black coffee :D Quote Link to comment Share on other sites More sharing options...
doug Posted September 16, 2004 Report Share Posted September 16, 2004 Well have a very stiff whiskey or three and go to bed. NOW. Quote Link to comment Share on other sites More sharing options...
mark2 Posted September 16, 2004 Report Share Posted September 16, 2004 Can't now, I'm all hyper wanting to fix it, I'll just have a giggle in the jokes perhaps, then OFF :lol:I'm hooked on this place I tell you Quote Link to comment Share on other sites More sharing options...
D4\/!d Posted September 16, 2004 Report Share Posted September 16, 2004 NOW GO TO BED. G'night Do as you're told !! Us old'ens are off to bed ourselves! :P Quote Link to comment Share on other sites More sharing options...
mark2 Posted September 16, 2004 Report Share Posted September 16, 2004 Yes, Dads :D :D :D Quote Link to comment Share on other sites More sharing options...
D4\/!d Posted September 16, 2004 Report Share Posted September 16, 2004 Sorted: Tools>options>advanced>allow web sites to install software :innocent:Edit:Do you have Tool Tips disabled? it was northamuk's remark about my Edit icon that gave me the clue. How spooky that I should have started that thread while dealing with this.Very many thanks mark2, for trying your hardest. Now up the wooden hill with you... Quote Link to comment Share on other sites More sharing options...
doug Posted September 16, 2004 Report Share Posted September 16, 2004 I get tools/options but can't find the advanced button Quote Link to comment Share on other sites More sharing options...
doug Posted September 16, 2004 Report Share Posted September 16, 2004 I meant under advanced can't find the allow web etc. Quote Link to comment Share on other sites More sharing options...
D4\/!d Posted September 16, 2004 Report Share Posted September 16, 2004 scroll down under software updatemaybe open up the + sign first Quote Link to comment Share on other sites More sharing options...
doug Posted September 16, 2004 Report Share Posted September 16, 2004 Found it under Tools/Options/Web features and allow web sites to install software/update mozilla is enabled. I have switxhed off the pop-up stopper. Perhaps i should try the original install page again.Edit tried the install again and no go. Perhaps I should stagger up the wooden stairs as well! Quote Link to comment Share on other sites More sharing options...
D4\/!d Posted September 16, 2004 Report Share Posted September 16, 2004 yep - it'll work like a dream (not a nightmare)...or maybe not! Try it again tomorrow when you're fresh.Hi Lester1, sorry we hijacked your thread :cheers2: Quote Link to comment Share on other sites More sharing options...
doug Posted September 16, 2004 Report Share Posted September 16, 2004 tried un-installing ans re-installing but no luck. Soon be tomorrow. Quote Link to comment Share on other sites More sharing options...
D4\/!d Posted September 17, 2004 Report Share Posted September 17, 2004 Hello doug, have you had a moment to have another go?Mark2, did you see that I solved the problem (with inspiration from Northamuk) Hooray! Quote Link to comment Share on other sites More sharing options...
mark2 Posted September 17, 2004 Report Share Posted September 17, 2004 Mark2, did you see that I solved the problem (with inspiration from Northamuk) Hooray!I did notice, now we just need to sort doug out, you're now the FF expert :flowers: :D Quote Link to comment Share on other sites More sharing options...
doug Posted September 17, 2004 Report Share Posted September 17, 2004 I'm here but a bit tied up for the mo. Trying to get a friend back up with MSN. I can see him and send him messages. He's getting the messages but can't see me. He's just deleting me and re-installing. Also doing wifes evening treatment in between times. Haven't even got my glass filled yet. Quote Link to comment Share on other sites More sharing options...
