dvd speed problem
Have you looked at Nero Drivespeed (Don't know what it does, but it sounds useful)
It come under Ahead Nero > Nero Toolkit on my start menu.
hi expertec
i don't know either but it still says the discs are 1x
Check that you have the latest version (update) of Nero as well.
hi pops pretty sure it's up to date
the disc just don't seem to be compatable. :unsure:
If there is a firmware update for your burner - make sure you read the installation instructions carefully and adhere to them. If not - you might well wreck your burner.
For example - with my LG drive - I have to connect it to the ribbon cable as the master - and not the slave as it is currently - before writing the firmware update.
Be brave - but be jolly careful.
hi expertec
thanks for the help
i will check for a firmware update.
thank alanho
i will be careful as it's a bit like flashing your bios i believe. :blink:
but first i think i will try different discs to see what happens
as i tink it may be a media fault. iwill get some the weekend.
cheers
bill
edit firmware update 27/11/03 drive was bought in jan 04 so i presume will be up to date.
