Mouse problem
artist
The pointer is walking up to the top of the screen on its own?
Also the screen is flickering when I scroll? (refresh at 75 - colour quality on highest)
Any suggestions? It was all ok yesterday and I have changed nothing.
I have done a virus scan, AdAware scan, defrag and disc clean up so far. Looked at the 'display' - seems ok. Also at the mouse settings - also same as normal.
Also try Start/Search and then type in Crazy mouse, if you find it uninstall it. It may possible show up in Add/Remove programs. There are idiots about who will download it onto your computer, I had it done on me once.
Have you tried a cold re-boot?
Turn everything off and switch off all power (pull the plug). Then re-boot.
Might work, might not but worth a try.
I did that - the flickering has stopped for now. - Mouse still heading for the top of the screen :huh:
No signs of it............
