i need some advice! :(
Redhat
I need some advice on what could be a life changing decision.
I've suspected for some time now that my girlfriend has been having an affair. The usual signs. Phone rings, I answer, someone hangs up.
She started going out 'with the girls' a lot recently although when I ask which girls it is always "Just some friends from work, you don't know them".
I always look out for her taxi coming home but she always walks down the drive although I can hear a car setting off. As if she has got out of the car round the corner. Why? Is it not a taxi?
I once picked her mobile up just to see what time it was and she went beserk and screamed that I should never touch her phone again and why was I checking up on her.
Anyway, I have never approached the subject with my g/f. I think deep downI just didn't want to know the truth but last night she went out again and I decided to check on her.
I decided I was going to hide behind my car which would give me a veiw of the whole street so I could see which car she gets out of. It was whilst crouched behind my car that I noticed rust around my rear wheel arch.
Should I take it into a body repair shop or should I buy some stuff and try to repair it myself?
I received a reply. Here it is.
Hi
If I were you Id get that rust on the car seen to itll be a better job and make sure that in future you check it in daylight hours and then you can catch it early and stop it from getting worse, as for the girlfriend!!!!!! Well, I would ask her right out about what she s up to otherwise you can only keep on guessing about it.
Good Luck
