nellie2 Posted January 8, 2006 Report Share Posted January 8, 2006 A friend is having problems uploading images to his site, he sent me this email and I was just wondering if anyone has any suggestions!trouble uploading image filesI am having trouble uploading image files. When I have up loaded they areeither only partly viewable or not there at all. I am using Terrapin FTP andhave been for a long time with out any problems. I have tried up loadingwith Zilla in case my Terrapin soft ware was at fault but again the imageswould not up load properly. I then tried to up loading to a differentserver, again without success. Any ideas as to how I can solve this problem would be gratefully received. Quote Link to comment Share on other sites More sharing options...
mark2 Posted January 8, 2006 Report Share Posted January 8, 2006 Could they be uploaded to imageshack perhaps as a test, see if they transfer there with no probs.Has anyone else tried to view them on his site yet ? does the fault lie at his end when viewing?is the URL to the uploaded pics correct, file names correct in relation to the missing ones ?Numpty here can only suggest start with the basics and double check each step. :paperbag1: Quote Link to comment Share on other sites More sharing options...
nellie2 Posted January 8, 2006 Author Report Share Posted January 8, 2006 I've viewed the pictures so it's not thatyes the urls are correct and the file names are correct as far as I know....I'll suggest the image shack idea! Quote Link to comment Share on other sites More sharing options...
mark2 Posted January 8, 2006 Report Share Posted January 8, 2006 If they appear to upload correctly to imageshack, can he download/copy (particularly the images) his whole site to a folder and compare to the back up already on his PC in case of corruption on the server ? Quote Link to comment Share on other sites More sharing options...
scuzzman Posted January 8, 2006 Report Share Posted January 8, 2006 They need to use BINARY as opposed to ASCII to transfer anything non-text, or the upload will become corrupted. Quote Link to comment Share on other sites More sharing options...
Tony Posted January 9, 2006 Report Share Posted January 9, 2006 You are correct scuzzman, but 99% of newish FTP clients auto detect what mode is needed.I know for a fact the alternative one he used to test with (File Zilla) does, so i don't think that, is the problem.Although what the problem is i don't know.Does he have enough space left on the web server?Tony Quote Link to comment Share on other sites More sharing options...
scuzzman Posted January 9, 2006 Report Share Posted January 9, 2006 True, but a lot of them can be configured to always use one transfer type, and I believe FileZilla is one of these. Would be worth a shot if nothing else...This might help too: Have your friend try the Windows/DOS FTP client.Just in case (output is in italics, comments in bold, "%" denotes an input prompt):Go to Start -> Run -> cmdC:\> ftp server.comWelcome message goes here....Username: their_usernamePassword: their_password likely will not show up as asterisks or anything...% asc Changes transfer mode to ASCIITransfer mode changed to ASCII% put test_picture1.jpg puts a test picture on the server using ASC transfer% bin Changes the transfer mode to BINARYTransfer mode changed to BINARY% put test_picture2.jpg puts a test picture on the server using BIN transfer% exitGoodbyeThen, try viewing test_picture1.jpg and test_picture2.jpg in a browser and see if the images are messed up in a similar way. If so, that could be the problem. I can guarantee that test_picture1.jpg WILL be messed up, but test_picture2.jpg shouldn't be. Quote Link to comment Share on other sites More sharing options...
nellie2 Posted January 9, 2006 Author Report Share Posted January 9, 2006 There is plenty of space on the server as far as I'm aware.I'll let you know how he gets on, I'm still waiting for feedback at the minute. Quote Link to comment Share on other sites More sharing options...
Topband Posted January 10, 2006 Report Share Posted January 10, 2006 nellie2,I had this very problem on one of my web sites a couple of years ago, the site was hosted by Geocities. The other two sites by different hosts were OK. I emailed Geocities about the problem and they corrected it in a couple of days.Has your friend asked their host? Quote Link to comment Share on other sites More sharing options...
nellie2 Posted January 10, 2006 Author Report Share Posted January 10, 2006 Not yet no... I'll let him know thanks! Quote Link to comment Share on other sites More sharing options...
Topband Posted January 10, 2006 Report Share Posted January 10, 2006 I then tried to up loading to a differentserver, again without success.I noticed they have tried a different server, so maybe that isn't the answer, oh well back to the drawing board :( Quote Link to comment Share on other sites More sharing options...
nellie2 Posted January 13, 2006 Author Report Share Posted January 13, 2006 Problem solved, sort of. It turns out he was having all sorts of other problems too, with his browser and such like and he decided to reformat. A bit drastic but everything is working as it should now! :) Quote Link to comment Share on other sites More sharing options...
scuzzman Posted January 13, 2006 Report Share Posted January 13, 2006 Glad he got it sorted, although I would've come to WF first before reformatting :P Quote Link to comment Share on other sites More sharing options...
Tony Posted January 13, 2006 Report Share Posted January 13, 2006 HiNellie in your second post you wrote<<I've viewed the pictures so it's not thatyes the urls are correct and the file names are correct as far as I know....I'll suggest the image shack idea!>>It is not clear wether or not you could view the pictures ok or not. if you could not view them ok, then i don't think the problem was his browser (unless he was trying to use his browser to upload the pics). but he says he used software to upload them.I am just pointing this out, as the problem could quite easy come back to haunt him. And i'm sure he would not want to do another reformat.I am thinking that maybe it was just a coinsidence that it was working after the reformat.If you could view the pics ok then all of my writing above is a load of rubbish, so just ignor it :)Tony Quote Link to comment Share on other sites More sharing options...
nellie2 Posted January 14, 2006 Author Report Share Posted January 14, 2006 Hi TonyNo I couldnt view them ok, I was seeing what he was seeing. He did try the image shack idea but his ie browser was borked and he just couldn't do it with opera.I'm begining to think that perhaps his registry was totally messed up too..... I did try the usual repair options but they didn't work. He was having a lot of problems with his connection dropping out as well. Quote Link to comment Share on other sites More sharing options...
