ɹəuəllıʍ ʇɐb Posted January 28, 2009 Author Report Share Posted January 28, 2009 You may have to wait for ever - this thing has been beta since I found it first (April 2007) Quote Link to comment Share on other sites More sharing options...
Dencandy Posted January 29, 2009 Report Share Posted January 29, 2009 Well, at least they're honest about it being Beta. Unlike some others, G**gle Chr*me for example! Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted January 29, 2009 Author Report Share Posted January 29, 2009 Frankly, I am astounded that Chrome is not in beta. Google usually keeps their software in beta for years and years; Gmail is still in beta... Quote Link to comment Share on other sites More sharing options...
Hb_Kai Posted February 3, 2009 Report Share Posted February 3, 2009 Really? How come? Quote Link to comment Share on other sites More sharing options...
andsome Posted February 4, 2009 Report Share Posted February 4, 2009 You may have to wait for ever - this thing has been beta since I found it first (April 2007) I have no problems with the standard version, so is there really any point in going Beta? :D Quote Link to comment Share on other sites More sharing options...
Vik Posted February 25, 2009 Report Share Posted February 25, 2009 cool link =) thank you =) Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted March 29, 2009 Author Report Share Posted March 29, 2009 Filehippo.com Update Checker v1.031 BETAhttp://www.filehippo.com/updatechecker/Changes: Improved program support and scanning methods. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted April 25, 2009 Author Report Share Posted April 25, 2009 Filehippo.com Update Checker v1.032 BETAhttp://www.filehippo.com/updatechecker/Changes: Improved program compatibility. Quote Link to comment Share on other sites More sharing options...
andsome Posted April 25, 2009 Report Share Posted April 25, 2009 Many thanks. At least this version does not keep showing me Windows messenger which is always disabled by me. :D Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted April 27, 2009 Author Report Share Posted April 27, 2009 Uninstall it, rather than disable. Quote Link to comment Share on other sites More sharing options...
andsome Posted April 27, 2009 Report Share Posted April 27, 2009 Uninstall it, rather than disable.It is part of the operating system. I have unticked it in Control Panel/add and remove programs/Add and remove windows components. Even after doing this the old program still showed it as need an update, the new version does not. :D Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted April 27, 2009 Author Report Share Posted April 27, 2009 I have removed it aeons ago; I don't know why you cannot uninstall it. Perhaps you updated it at some time to a newer version? Quote Link to comment Share on other sites More sharing options...
andsome Posted April 27, 2009 Report Share Posted April 27, 2009 I have it disabled but cannot see how to actually uninstall it. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted April 27, 2009 Author Report Share Posted April 27, 2009 That is odd - all these components (installed or not) show 0.0MB! Quote Link to comment Share on other sites More sharing options...
andsome Posted April 27, 2009 Report Share Posted April 27, 2009 That is odd - all these components (installed or not) show 0.0MB!Here are some that do not. :D Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted August 18, 2010 Author Report Share Posted August 18, 2010 Filehippo.com Update Checker v1.038http://www.filehippo.com/updatechecker/Changelog:Improved for .NET 4.0 compatibility. Quote Link to comment Share on other sites More sharing options...
who Posted November 10, 2010 Report Share Posted November 10, 2010 I tried the update checker it works but not properly may be it is because of missing files in windows .Any way thanks for the software. Quote Link to comment Share on other sites More sharing options...
Lamb Chop Posted March 25, 2011 Report Share Posted March 25, 2011 I just downloaded this as no longer use Secunia and it gave me 12 programs to update - d/l the ones I use 4 - uninstalled old versions I never use and then when I tried to go to downloads file to start installing - programs would not respond - and didnt even send a msg back. So uninstalled. My computer seems touchy these days. Quote Link to comment Share on other sites More sharing options...
