I need help after a virus clean up.
Alan2273
A quick resume.
I built a computer for a charity about 3 years ago, and it has run great till a couple of days ago.
He asked me to have a look at it and it had a virus on it, (as he had not renewed his virus protection)
The virus was Worm bv/zz, which changes doc extensions to scr extensions.
I installed AVG and it found 19 infected word documents, so I deleted all the files, updtaed AVG and went home.
After reding about this worm I noticed that when antivirus software deletes corrupted files it also deletes SCVHOST and Spool.exe.
Today he rang me to say it will not boot into Windows.
I know I can do an XP repair, but is there a quicker way to put these missing .EXE back into the operating system.
Have you thought about using a live linux disc to copy/paste a known clean version back into the correct place ?
Before having to repair install, it may just work.
I believe AVG keeps a log file of deletions, you ought to be able to access this using the linux cd to find out where it was deleted from.
