Guest spook Posted February 4, 2003 Report Share Posted February 4, 2003 Hi DdraigcochTa. Quote Link to comment Share on other sites More sharing options...
Guest Ddraigcoch Posted February 4, 2003 Report Share Posted February 4, 2003 You're welcome :D Quote Link to comment Share on other sites More sharing options...
popeye Posted February 12, 2003 Report Share Posted February 12, 2003 Here's a little freebie thats not been mentioned and I find useful.SURE DELETE. at http://www.wizard-industries.com ;) Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted February 22, 2003 Report Share Posted February 22, 2003 heres a useful site with good tweaks http://www.x9000.net/ Quote Link to comment Share on other sites More sharing options...
Tony Posted March 3, 2003 Report Share Posted March 3, 2003 Hi I find this a handy little thinghttp://www.xp-antispy.deXP-AntiSpy is a little utility that let's you disable some built-in update and authetication 'features' in WindowsXP.For example, there's a service running in the background wich is called 'Automatic Updates'. I don't know what this service transfers from my machine to other machines on the internet, especially the MS ones. So I play it safe and disable such functions. If you like, you can even disable these function manually, by going through the System and checking or unchecking some checkboxes. This will take you approximately half an hour. But why wasting time when a little neat utility can do the same in 1 minute? This utility was successfully tested by lots of users, and was found to disable all the known 'Suspicious' Functions in WindowsXP. It's customizeable, but comes up with the Default settings, which are recommended.All the bestTony Quote Link to comment Share on other sites More sharing options...
Electric Hermit Posted April 5, 2003 Report Share Posted April 5, 2003 I can play this game.I tend to like simple little things which do one thing but do it very well.That's why I married the wife! Boom! Boom! :D But seriously, folks ....Volume Tray makes it really easy to adjust the volume simply by clicking on a System Tray icon with the left or right mouse button. Highly configureable with lots of skins and icon variations. Another neat feature is that it remembers the last volume setting for each user. No more logging on after someone else and being deafened.http://glorysoft.omsk.ru/volumetray.html Quote Link to comment Share on other sites More sharing options...
Electric Hermit Posted April 5, 2003 Report Share Posted April 5, 2003 Here's another clever little tool. JDN Reserve can significantly speed up tasks such as secure disk cleaning. It does this by setting aside, or reserving, a default (90%) or user-defined portion of unused disk space. Only the unreserved space is used, so only this smaller amount of space has to be checked. Simple but brilliant!http://www.geocities.com/jdn_reserve/ Quote Link to comment Share on other sites More sharing options...
Electric Hermit Posted April 5, 2003 Report Share Posted April 5, 2003 SpamPal is my choice for email filtering. It is very easy to install and configure and no effort whatever to use. There are a number of plugins available as well as frequent updates for the database and a helpful users forum. Most importantly, it is highly effective and makes the chore of managing spam a lot less tiresome.http://www.spampal.org/ Quote Link to comment Share on other sites More sharing options...
Paul Posted April 5, 2003 Report Share Posted April 5, 2003 RZDLL backup is a tool which will scan your system for .DLL files, make a copy and store them in its own folder as a backup, then when a program complains of a missing or corrupt .DLL then all you have to do is resore it.http://asia.cnet.com/downloads/pc/swinfo/0...8018400s,00.htm Quote Link to comment Share on other sites More sharing options...
Electric Hermit Posted April 5, 2003 Report Share Posted April 5, 2003 FontRenamer is a simple tool which with a couple of clicks replaces those confusingly cryptic names TrueType fonts often have with something more meaningful.http://www.neuber.com/free/fontrenamer/ Quote Link to comment Share on other sites More sharing options...
Tankus Posted April 5, 2003 Report Share Posted April 5, 2003 Another av for you Hermit Quote Link to comment Share on other sites More sharing options...
Electric Hermit Posted April 5, 2003 Report Share Posted April 5, 2003 TankusNice! But I still prefer the old one I think. Quote Link to comment Share on other sites More sharing options...
Electric Hermit Posted April 5, 2003 Report Share Posted April 5, 2003 TankusHey! I didn't realise that avatar was animated. Excellent! Quote Link to comment Share on other sites More sharing options...
Boris Posted April 6, 2003 Report Share Posted April 6, 2003 This is new - could be useful ? - if you back-up this way (I can't :( )Disk Image Viewer 0.5 from :- http://www.softwarium.com/divwin.htmlAllows you to browse floppy and hard disk images in EXT2 (Linux) and FAT (DOS, Windows) file systems. It also lets you copy files from the images as well. Quote Link to comment Share on other sites More sharing options...
AndySD Posted May 5, 2003 Report Share Posted May 5, 2003 A little program I cant do without when designing websites and editing images Color Pickerhttp://www.iconico.com/colorpic/ Quote Link to comment Share on other sites More sharing options...
Guest Damo Posted May 6, 2003 Report Share Posted May 6, 2003 Nice link AndySD!!! Quote Link to comment Share on other sites More sharing options...
Guest whizwrinkly Posted May 6, 2003 Report Share Posted May 6, 2003 Thanks AndySD. Simple, but very handy for me :) (Hope its as good as it looks, just gonna download now) <_< Cheers. whiz... Quote Link to comment Share on other sites More sharing options...
AndySD Posted May 6, 2003 Report Share Posted May 6, 2003 whizwrinklyI find it invaluable just unzip it to the c drive and then Right click on it and put a shortcut to the Desktop.... drag this shortcut to Quick Start on the Task Bar. I tend to start it then leave it minimised in the Task Bar. Anyway have a play and see what you think.Andy Quote Link to comment Share on other sites More sharing options...
Boris Posted May 26, 2003 Report Share Posted May 26, 2003 Try this as an alternative to AIDA32 or SiSoft Sandra ?Just out - PC Wizard 2003 from http://www.cpuid.com Quote Link to comment Share on other sites More sharing options...
mmanya Posted June 23, 2003 Report Share Posted June 23, 2003 http://www.xs4all.nl/~mp2004/X-Setup Quote Link to comment Share on other sites More sharing options...
Electric Hermit Posted July 25, 2003 Report Share Posted July 25, 2003 1st Page 2000 is a professional HTML editor. And it's free!http://www.evrsoft.com/ Quote Link to comment Share on other sites More sharing options...
Electric Hermit Posted July 25, 2003 Report Share Posted July 25, 2003 A collection of over 50 tools which require no installation and whose tiny size belies their usefulness. http://www.freewarehits.de/ToolsPackage.htm Quote Link to comment Share on other sites More sharing options...
casey Posted July 25, 2003 Report Share Posted July 25, 2003 1st Page 2000 says its no longer available for download.Casey Quote Link to comment Share on other sites More sharing options...
Electric Hermit Posted July 25, 2003 Report Share Posted July 25, 2003 caseySorry about that. It is less than a week since I downloaded 1st Page 2000 myself, so I didn't check the link. Try this one. http://www.voodoofiles.com/4836 Quote Link to comment Share on other sites More sharing options...
casey Posted July 25, 2003 Report Share Posted July 25, 2003 Thanks, 1st Page downloaded O/K from there.casey Quote Link to comment Share on other sites More sharing options...
