backkom Posted August 22, 2011 Report Share Posted August 22, 2011 Dear Friends, When I try to write files from my PC to CD I get the following message (( Windows encountered a problem when trying to copy this folder. What do you want windows to do?))I clicked on "retry" but didn't work and when I click "skip" didn't work too.My computer: Microsoft Windows XP RegardsBackkom Quote Link to comment Share on other sites More sharing options...
-pops- Posted August 22, 2011 Report Share Posted August 22, 2011 Are you using the CD writing software included as part of XP?I never managed to get that to work successfully and reverted to using an independent program (Nero) and have continued to do so ever since. Quote Link to comment Share on other sites More sharing options...
Alan2273 Posted August 22, 2011 Report Share Posted August 22, 2011 You could give this one a try, it is for XP./>http://cdburnerxp.se/ Quote Link to comment Share on other sites More sharing options...
pawz7 Posted August 22, 2011 Report Share Posted August 22, 2011 it might simply be that you have a duff batch of cd's - this happened to a friend of ours a month back. Quote Link to comment Share on other sites More sharing options...
doug Posted August 22, 2011 Report Share Posted August 22, 2011 I've had that both with duff CD's and duff DVD's. Recently produce a whole load of DVD's for family and friends. Got fed up with producing toasters so I do my first burn with RW DVD's check those the copy to DVD's. Might be worth considering at least with RW's you don't waste discs when trialling something. Quote Link to comment Share on other sites More sharing options...
bludgard Posted August 22, 2011 Report Share Posted August 22, 2011 ... I do my first burn with RW DVD's check those the copy to DVD's. Might be worth considering at least with RW's you don't waste discs when trialling something.I do the same with .ISOs. Good advice....;) Quote Link to comment Share on other sites More sharing options...
backkom Posted August 23, 2011 Author Report Share Posted August 23, 2011 Well, I really thank you all from the bottom of my heart for your Posted. Quote Link to comment Share on other sites More sharing options...
