AlanHo Posted January 22, 2013 Report Share Posted January 22, 2013 When I type a post using IE10 the carriage return is not working. I cannot create a new line. It works OK on two other forums I post on so it seems confined to just this forum. Firefox is working OK though. This post is all one paragraph because I am using IE10 and Windows 8. Quote Link to comment Share on other sites More sharing options...
Irene Posted January 22, 2013 Report Share Posted January 22, 2013 Take a look at this thread, Alan:http://community.inv...-in-ie10-r38650The last post provides a couple of links which are said to be fixes. Quote Link to comment Share on other sites More sharing options...
AlanHo Posted January 22, 2013 Author Report Share Posted January 22, 2013 Thanks Irene - unfortunately the fix is way over my head - I have no idea how to apply hundreds of lines of code. Quote Link to comment Share on other sites More sharing options...
AlanHo Posted January 22, 2013 Author Report Share Posted January 22, 2013 This is a perfect example of sod's law at work. I have tried putting IE10 into compatibility mode for IE9 and IE8 but the problem remains. The return key does nothing. I have also tested 7 other forums I occasionally participate in and none of them have the same problem. It is obviously something to do with the software used on this forum for rendering text. I shall have to compile text in Word (as now) and then paste it here until the problem is resolved. Quote Link to comment Share on other sites More sharing options...
D4\/!d Posted January 22, 2013 Report Share Posted January 22, 2013 I do not use IE10 [my PC will not accept it...nevermind I'm not bothered]Alan, try Shift+Enter - alright holding Shift>press carriage return.I understand it is a soft return rather than a paragraph return - and I often use it to segregate formatting.It might help. Quote Link to comment Share on other sites More sharing options...
AlanHo Posted January 22, 2013 Author Report Share Posted January 22, 2013 I have tried that - plus various other key combinations and function keys - but now't works. Googling the problem reveals that it applies to just a few forums that use a particular engine and that this is one of them. The solution is for the forum software to be updated to take account of the latest browser specifications. Quote Link to comment Share on other sites More sharing options...
rong Posted January 22, 2013 Report Share Posted January 22, 2013 Are all the IE users having the same problem here? Quote Link to comment Share on other sites More sharing options...
AlanHo Posted January 22, 2013 Author Report Share Posted January 22, 2013 Perhaps alan2273 can give some feedback. I believe he has Windows 8 on his laptop. Quote Link to comment Share on other sites More sharing options...
andsome Posted January 23, 2013 Report Share Posted January 23, 2013 Are all the IE users having the same problem here?I don't use IE10, and would imagine that at this stage very few do in comparison to IE9. Quote Link to comment Share on other sites More sharing options...
