cinque8 Posted April 30, 2014 Report Share Posted April 30, 2014 Hi, has the Internet Explorer security problem been fixed, and if so, do you have to download an update before using IE again? Thanks Quote Link to comment Share on other sites More sharing options...
Boris Posted April 30, 2014 Report Share Posted April 30, 2014 Make sure you are running the latest version of Adobe Flash Player (13.0.0.206) Quote Link to comment Share on other sites More sharing options...
Belatucadrus Posted April 30, 2014 Report Share Posted April 30, 2014 Read the latest security advisory they've suggested a workround that involves deregistering the VGX dll, but I don't think this is something that's been done automatically by Windows update. It'll also depend what version of Windows and IE you're running as it looks as if anything older than Vista or IE 10 may never receive a fix.Either way I'd suggest using an alternative, permenantly on XP or older and at least until Microsoft issue some more definative statement for anything newer. Quote Link to comment Share on other sites More sharing options...
cinque8 Posted April 30, 2014 Author Report Share Posted April 30, 2014 Thanks for the info guys. I am running Windows Vista Quote Link to comment Share on other sites More sharing options...
Belatucadrus Posted May 2, 2014 Report Share Posted May 2, 2014 You should have had the appropriate update by now and Microsoft even extended the fix to cover XP. Quote Link to comment Share on other sites More sharing options...
Irene Posted May 2, 2014 Report Share Posted May 2, 2014 You should have had the appropriate update by now and Microsoft even extended the fix to cover XP. Pat has posted a link to the update, here: http://forums.windowsforum.org/index.php?showtopic=52033&p=351683 Quote Link to comment Share on other sites More sharing options...
