BrandonP Posted September 26, 2014 Report Share Posted September 26, 2014 I have a computer with Windows 7 Ultimate 64-bit and I'm unable to listen to any audio. The PC has an Asus P5PE-VM motherboard which has ADI AD1888JCPZ High Definition Audio 6-channel Codec. I've tried to have windows search windows update for a driver but it didn't find anything. Any assistance in helping me fix this would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
ɹəuəllıʍ ʇɐb Posted September 27, 2014 Report Share Posted September 27, 2014 First thing to check if the sound isn't muted by accident. Quote Link to comment Share on other sites More sharing options...
Gandalph Posted September 28, 2014 Report Share Posted September 28, 2014 Second thing to check, Does your Audio Drivers require a re-installation. Check under Driver Management. Quote Link to comment Share on other sites More sharing options...
southmp3plus Posted December 7, 2014 Report Share Posted December 7, 2014 Check the BIOS to make sure the onboard audio is enabled. You can also try a BIOS update if there is one available. If no update, reset the BIOS by pulling the CMOS battery or using the reset jumper. Quote Link to comment Share on other sites More sharing options...
southmp3plus Posted December 19, 2014 Report Share Posted December 19, 2014 Hi, First try to restore ur system on the point just before u lost ur sound : Start/All the programs/Accessories/System Tools/System Restore. If that doesn't match, u'll have to re-install ur sound card. Tell the brand and the model of ur computer (or of ur MB if ur computer is a no-brand one) and I probably will be able to give u a linK for free downloading the driver u need. Quote Link to comment Share on other sites More sharing options...
Belatucadrus Posted December 19, 2014 Report Share Posted December 19, 2014 I wouldn't bother southmp3plus, BrandonP posted the question back in September and from the look of things hasn't been back to the forum since, presumably he found a fix somewhere else. Quote Link to comment Share on other sites More sharing options...
