Irene Posted November 24, 2015 Report Share Posted November 24, 2015 I thought it might be useful to gather together the issues which are as a direct result of the recent upgrade. This will then provide a central place for Craig to look at the problems which need to be addressed. Just reply to this thread explaining as clearly as possible what your difficulty is. . . Quote Link to comment Share on other sites More sharing options...
AlanHo Posted November 24, 2015 Report Share Posted November 24, 2015 Images I am not able to post an image using the "Insert Other Media" and the subsequent "Insert Image from URL" buttons. The image appears in the post window but when I submit the reply it has turned into garbled text. If I copy a jpg image from another source and paste it into the post window - the same thing happens - it appears in the window but turns into garbled text after I submit the post. I have tried inserting images using BB code which fails. It could be done before the forum mods. If I use the "Drag files here to attach or choose file" facility I can post a browsed image and it is retained. However - I have not found a way of subsequently editing or deleting an image. It has been suggested that it is possible and that a small trash bin icon appears in the bottom right when you hover your mouse cursor there - in my case I can find no way of getting this icon to show - I have hovered and pressed just about every possible key and nowt happens. All my images for posting on forums are stored on Photobucket. I have not been able to use any of the photobucket links to post them here - but it was fine before the forum was changed. I am using Windows 10 and Firefox. I have tried using IE11 and EDGE but get the same results. Quote Link to comment Share on other sites More sharing options...
Irene Posted November 25, 2015 Author Report Share Posted November 25, 2015 1. The option to show that a post is edited does not work: The 'check box' makes no difference. 2. The formatting bar in the reply box is inadequate: No Emoticons available in IE11 & Firefox on Windows 10, but are there in Apple product. No choice of fonts. NOW FIXED Right / left pointing arrows which simulate tabulation. NOW FIXED The 'Undo' is absent. NOW FIXED 3. Various problems with inserting pictures. Also, some member avatars have disappeared since the upgrade. 4. No preview available before posting. I am sure there are more, which I will add in due coourse. Quote Link to comment Share on other sites More sharing options...
Irene Posted November 25, 2015 Author Report Share Posted November 25, 2015 Information absent on the opening Main Menu screen - examples: Users online. NOW FIXED latest threads started. NOW FIXED Birthdays. NOW FIXED Quote Link to comment Share on other sites More sharing options...
Irene Posted November 25, 2015 Author Report Share Posted November 25, 2015 The large 'Browse' link at top right of Main Menu does not work on Apple iPad. Quote Link to comment Share on other sites More sharing options...
AlanHo Posted November 25, 2015 Report Share Posted November 25, 2015 Irene - I can post emoticons Windows 10 + Firefox Windows 10 + IE11 Windows 10 + EDGE All using my Desktop computer Quote Link to comment Share on other sites More sharing options...
Irene Posted November 25, 2015 Author Report Share Posted November 25, 2015 5 minutes ago, AlanHo said: Irene - I can post emoticons Windows 10 + Firefox Windows 10 + IE11 Windows 10 + EDGE All using my Desktop computer This is crazy! It's incomprehensible! I tried a short while ago on my desktop with negative result. At present I am on iPad and can. Quote Link to comment Share on other sites More sharing options...
Irene Posted November 25, 2015 Author Report Share Posted November 25, 2015 Managed content notifications don't work. Quote Link to comment Share on other sites More sharing options...
andsome Posted November 29, 2015 Report Share Posted November 29, 2015 Had problems getting in, but that was probably my fault as I had to re log in after the upgrade. Smilies appear to work on the Windows 7 computer, not tried on my I pad yet. This is an attempt to edit this post from my I pad,having first made the post on my Windows 7 computer. Also trying a similie. I am not entering anything in the reason to edit box. 1 Quote Link to comment Share on other sites More sharing options...
andsome Posted November 29, 2015 Report Share Posted November 29, 2015 The above seemed to work. What does the minus 24 mean by my number of posts and gender? 1 Quote Link to comment Share on other sites More sharing options...
Boris Posted November 29, 2015 Report Share Posted November 29, 2015 2 hours ago, andsome said: The above seemed to work. What does the minus 24 mean by my number of posts and gender? Your reputation. Click on it to see your rating :) 1 Quote Link to comment Share on other sites More sharing options...
IMTNT Posted December 1, 2015 Report Share Posted December 1, 2015 On 11/29/2015, 3:10:24, andsome said: What does the minus 24 mean by my number of posts and gender? You must have ruffled some feathers. Good job. Quote Link to comment Share on other sites More sharing options...
AlanHo Posted December 1, 2015 Report Share Posted December 1, 2015 Reputation Votes On a whim I decided to give some posts a + reputation vote yesterday. 4 votes in all. I tried to do the same today and the forum will not let me. I get a window open that tells me I am allowed to make a maximum of 10 reputation votes per day. I know it's minor stuff in the big scheme of things - but if not corrected - andsome's negative score will languish at the bottom of the league table I consider the feature to be a bit frivolous anyway - we would be better without it. Quote Link to comment Share on other sites More sharing options...
Irene Posted December 1, 2015 Author Report Share Posted December 1, 2015 Take a look at this old thread... https://www.windowsforum.org/topic/48088-reputation/#comment-322356. Quote Link to comment Share on other sites More sharing options...
andsome Posted December 1, 2015 Report Share Posted December 1, 2015 On 29 November 2015 at 10:20:59, Boris said: Your reputation. Click on it to see your rating :) It says that there is nothing there yet? I had a liquorice alsort showing today,when I clicked on it it said that I had been quoted.(so what). I don't see the point. The forum was OK before apart from being very slow at times. I hope that it is not going to get like the dreaded face ache website. Quote Link to comment Share on other sites More sharing options...
Irene Posted December 1, 2015 Author Report Share Posted December 1, 2015 45 minutes ago, andsome said: It says that there is nothing there yet? I had a liquorice alsort showing today,when I clicked on it it said that I had been quoted.(so what). I don't see the point. The forum was OK before apart from being very slow at times. I hope that it is not going to get like the dreaded face ache website. I referred to the old thread because I thought it might explain where the 'rating' had come from. Looks to me like history may simply have been carried forward into the upgrade. Quote Link to comment Share on other sites More sharing options...
AlanHo Posted December 1, 2015 Report Share Posted December 1, 2015 That was my guess - you have a better memory than me - I can't remember posts back in 2011 Quote Link to comment Share on other sites More sharing options...
