Content: Slate Blackcurrant Watermelon Strawberry Orange Banana Apple Emerald Chocolate Marble
Background: Slate Blackcurrant Watermelon Strawberry Orange Banana Apple Emerald Chocolate Marble
Pattern: Blank Waves Notes Sharp Wood Rockface Leather Honey Vertical Triangles
Welcome to Windows Forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
johnoo
CPU Running Temperature Intel Core i3 3220
7 posts in this topic
Don't know why I do it, but I use "Speccy" monthly & note running temperatures.
Generaly the CPU Temperature is 25/28 C.
Today it was recorded as 39C
Is this within normal range or have I a problem coming?
0
Share this post
Link to post
Depends on what CPU you have, but this guide sheet seems to indicate you're still in the acceptable range for an idling PC, not yet into the normal working temperature range.
So no cause to worry as yet, but it may be worth giving it a spring clean with an air duster to ensure all the air ducts and cooling fins are dust free.
0
Share this post
Link to post
Thanks.
The type is a Intel core i3 3220 "Ivy Bridge"
Looking at the guide sheet Idle Temp is 28/35, Normal 50/60C Max 65C
So as you OK, but I will keep watch & vacuum out the dust
0
Share this post
Link to post
Most, if not all, CPUs nowaday have a built-in non-selfdestruct mechanism where the device will shut down before it reaches dangerously high temperatures.
0
Share this post
Link to post
Thanks, good to know, but my CPU has reverted back to a range of 25/28C
So no problem, I hope
0
Share this post
Link to post
my computer is always hot , i didn't know you could check or that temperature,  i am new to this.
0
Share this post
Link to post
To check the temperature try Speedfan. As to your computer being hot, how hot, what type of computer and where is it being used.
0
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
