Irene Posted January 27, 2018 Report Share Posted January 27, 2018 Olive oil mash · 1 kg / 2lb 2oz King Edward (or similar) potatoes, peeled and cut into chunks · pinch salt · 75-110ml / 3-4fl.oz. extra virgin olive oil · salt and freshly ground black pepper 1. Place the potatoes into a large saucepan and cover with water. Add a pinch of salt, place on the heat and bring to the boil. 2. Simmer for 10-15 minutes until tender. 3. Drain well and return to the pan over a low heat for a few seconds to remove any excess moisture. 4. Using a potato masher or ricer, mash well, adding the olive oil to slacken and flavour the potatoes. Season with salt and freshly ground black pepper. Quote Link to comment Share on other sites More sharing options...
catgate Posted January 27, 2018 Report Share Posted January 27, 2018 I like the name of this dish. It is reminiscent of the names of dances prolific in the days of my youth. "Doing the "Olive Oil Mash" " Quote Link to comment Share on other sites More sharing options...
-pops- Posted January 27, 2018 Report Share Posted January 27, 2018 I've stopped boiling potatoes - I much prefer cooking whole in the microwave and then either scooping out the flesh or allowing to cool (until they can be handled) and peeling the skin away with the fingers. Cooked this way, there is no problem with the potatoes disintegrating from the boiling or absorbing loads of water. Quote Link to comment Share on other sites More sharing options...
andsome Posted January 28, 2018 Report Share Posted January 28, 2018 I never peel spuds, the peel is the best part. Quote Link to comment Share on other sites More sharing options...
AlanHo Posted January 28, 2018 Report Share Posted January 28, 2018 You microwave spuds - cut them in half, scoop out the innards and just eat the skin then?... Quote Link to comment Share on other sites More sharing options...
andsome Posted January 28, 2018 Report Share Posted January 28, 2018 2 hours ago, AlanHo said: You microwave spuds - cut them in half, scoop out the innards and just eat the skin then?... We eat the whole spud. The only time we use a microwave for spuds is for jacket spuds. It is a combination machine mandate can bake two spuds in twenty minutes. I always let the cook in combo mode for the allotted time,then do them for another five minutes at 250 degrees. They are perfect. Quote Link to comment Share on other sites More sharing options...
