moon Posted November 22, 2003 Author Report Share Posted November 22, 2003 Well, in the boot screen there was an F3 key option to halt and set up RAID. ( You've got to be bloody quick, aincha ?) The first option was 'Create Mirrored set' which I selected. Now, the boot screen shows a mirrored set ( my two Seagates) but I can't find anything in the BIOS setup or manual with a 'boot from RAID' option. In fact , the manual's written by a moron e.g. 'To select more auctions press Cntl+F1 widden' :D Quote Link to comment Share on other sites More sharing options...
moon Posted November 22, 2003 Author Report Share Posted November 22, 2003 OK, in the BIOS the SATA/RAID/SCSI Boot Order is greyed out. The manual says its available when Boot device is set to SCSI. In the Advanced Menu (F2 :) ) I can scroll until SCSI is top of the list BUT I can't find a way to select it. 'Enter' does nowt and leaving it at the top and pressing 'Esc' just reverts the list to Floppy at the top. How is it selected ? There's naff all in the manual. Quote Link to comment Share on other sites More sharing options...
Boris Posted November 22, 2003 Report Share Posted November 22, 2003 Space Bar ? Quote Link to comment Share on other sites More sharing options...
moon Posted November 22, 2003 Author Report Share Posted November 22, 2003 Not right now, boris, I'm busy. Get one in for me and I'll catch you later. :D Quote Link to comment Share on other sites More sharing options...
mark2 Posted November 22, 2003 Report Share Posted November 22, 2003 pgup/pgdn ? Quote Link to comment Share on other sites More sharing options...
Boris Posted November 22, 2003 Report Share Posted November 22, 2003 Will an Intergalactic Gargle Blaster be OK ? :D Quote Link to comment Share on other sites More sharing options...
Boris Posted November 22, 2003 Report Share Posted November 22, 2003 Tried Ctrl + F1 ?What is the Bios make ? Quote Link to comment Share on other sites More sharing options...
moon Posted November 22, 2003 Author Report Share Posted November 22, 2003 Pgup/pgdn gives a selection of sequences, mark, none of which has SCSI at the top. Second place is the best it will do, after HDD 4, which I don't have. :DIt's AWARD, boris, which I'm used to but mine doesn't have this menu option thingy.Will an Intergalactic Gargle Blaster be OK ?ROFL ! :D Quote Link to comment Share on other sites More sharing options...
mark2 Posted November 22, 2003 Report Share Posted November 22, 2003 without HDD 4 surely it will then look to SCSI to boot from then ? ?ie when Bios/s were set to boot floppy then HD (way back when ) it chose the second option if no floppy ? Quote Link to comment Share on other sites More sharing options...
Boris Posted November 22, 2003 Report Share Posted November 22, 2003 Logically Yes Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted November 22, 2003 Report Share Posted November 22, 2003 hes my bios bit blurred mind Quote Link to comment Share on other sites More sharing options...
moon Posted November 22, 2003 Author Report Share Posted November 22, 2003 OK, I'll set that and hit 'enter' . Hold up. Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted November 22, 2003 Report Share Posted November 22, 2003 another pic Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted November 22, 2003 Report Share Posted November 22, 2003 and make sure raid is enabled Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted November 22, 2003 Report Share Posted November 22, 2003 create array Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted November 22, 2003 Report Share Posted November 22, 2003 select boot drive Quote Link to comment Share on other sites More sharing options...
moon Posted November 22, 2003 Author Report Share Posted November 22, 2003 OK, RAID is selected. Which order should I set ? SATA, SCSI or RAIDAHA ! I only get one option eh ? Cunning. :D Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted November 22, 2003 Report Share Posted November 22, 2003 do you think it will be finished for xmas :D Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted November 22, 2003 Report Share Posted November 22, 2003 still would like a link to the manual. Quote Link to comment Share on other sites More sharing options...
monkeyhanger Posted November 23, 2003 Report Share Posted November 23, 2003 ellas. you will find these two sites interesting.http://uk.giga-byte.com/Motherboard/Suppor...N400%20Pro2.htmhttp://uk.giga-byte.com/MotherBoard/FileLi..._3112_e_002.pdfalso boot from SATA. Quote Link to comment Share on other sites More sharing options...
moon Posted November 23, 2003 Author Report Share Posted November 23, 2003 I bailed out last night before installing the O/s. I'm playing about in the BIOS before I do, so any tips welcome. I'm set to boot from SATA . Firstly, I don't have anything connected to 'System Fan'. The case has three internal fans which are independent of the mobo. I've set 'System Fan' to 'Disabled' and activated the fans warning. Correct ? PS. Thanks for the help last night chaps. Much appreciated. :) Quote Link to comment Share on other sites More sharing options...
Guest Grim Reaper Posted November 23, 2003 Report Share Posted November 23, 2003 I bailed out last night before installing the O/s. I'm playing about in the BIOS before I do, so any tips welcome. I'm set to boot from SATA . Firstly, I don't have anything connected to 'System Fan'. The case has three internal fans which are independent of the mobo. I've set 'System Fan' to 'Disabled' and activated the fans warning. Correct ? PS. Thanks for the help last night chaps. Much appreciated. :)if the case fans are independent of the mobo then yes, set system fan to disabled........ Quote Link to comment Share on other sites More sharing options...
moon Posted November 23, 2003 Author Report Share Posted November 23, 2003 Right. Can I use the mobo 'Sys fan' connection to run another fan for the graphics card ?Also, the BIOS reports the cpu temp. as 50. This rises to 55 after about a half hour. Is this normal ? Lots of peeps tell me that the retail box fan is inadequate. Quote Link to comment Share on other sites More sharing options...
Guest Grim Reaper Posted November 23, 2003 Report Share Posted November 23, 2003 the cpu temp will rise with the load that is being placed on it.......55 deg is not too bad but in time you may with to consider getting a copper heatsink and a more powerful fan.......you can use the sys fan connection to put a fan anywhere one will fit.... Quote Link to comment Share on other sites More sharing options...
moon Posted November 23, 2003 Author Report Share Posted November 23, 2003 Ta. It's nice to have one's own team of boffins :D The FSB default is 133. Max. setting is 200. My RAM is DDR 400. I'm confused. :)Are these settings OK ?Sys Performance= Normal ( Default value)FSB Frequency = 200MHz ( Default is 133) Memory Frequency = Auto ( SPD ? is the default setting)AGP Frequency = Normal ( Default value) Quote Link to comment Share on other sites More sharing options...
