AVG problem
artist
I have the tweak - Still can't get the updates to download.
Keep on getting a message telling me that 'automatic connection to the internet could not be established.'
I am considering removing it and reinstalling.
I have tried to get the downloads direct from Grisoft, with no success.
The database I have is 28.3.04. It's programmed to update if it's older than two days. :(
Have a look at the version number artist. If it's AVG 6 then it should be:
6.0.651 2/9/2003.
Virus update is number 417. 5/4/04
I did a fresh install last week and it's still the same. IE: Can take several attempts to download but it will download if you try tree or four time consecutively.
Try the .com a couple of times then the CZ site. Also the best time is approx.
4-6am so set your auto update for that time and leave your PC on that night. Also reduce the update time to 1 day.
[Edit] 418 just released a short time back. :unsure:
[Edit] 419 has just come through!! Third release today. :lol:
Guest ellas
maybe there messing people around so they buy the full version,theres plenty of full av's with a years free updates available like the panda or ez trust ones.
Artist, if it's any help, I have not been able to get AVG to automatically download any updates for the last few weeks either.
It seems to be a problem at thier end.
I am currently doing the downloads manually from here V6 Updates
The instructions are on the page.
Mr. M.
Well I tried - nothing!
Totally uninstalled and have now reinstalled. At least the data base is up to date!
I can't face any more rejections :( So will check the updates tomorrow. :D
so what was up with the e trust one bvw.
Just a bit "clumsy" to use Ellas....... been used to AVG, it's nice and simple to use.
E-Trust had quite a bit running in the background as well. I've got the free 1yr use of it on the M$ updates cd, but, again, I like AVG.
Nice and easy to use, that's all.
When Grisoft first introduced AVG 7 there were rumours that version 6 would no longer be supported after a time sufficient for users to change over. Perhaps this is now taking place.
I changed to version 7 when it was first issued because AVG had given me years of good service I felt obliged to offer something back for all their efforts. After I paid the small amount required I found that it covers updates for virtually ever more!
Yes, I have been more than happy with it too. I'll try avast and see how it goes.
I may have to PAY for it! (AVG) :)
  • 2 weeks later...
