Andy-2004 Posted June 1, 2004 Report Share Posted June 1, 2004 Ok i just downloaded FC2 and i need to burn the 3 .iso'sSo i first tryed that ISO recorder power toy thing...And i got the disk cannot be used please insert a blank one and try again...THE DISKS ARE BLANK and i tryed 3 others to be sure....same messageAlso i tryed alcohol 120% and when i press start i get "device busy"Also2: when i put in the CD i dont get any auto run thingiealso3: when i put ion the disk....the wee i con in my computer doesnt cahnge to a disk it stays as a wee dive with a disk above it.HELP :censored: Quote Link to comment Share on other sites More sharing options...
Andy-2004 Posted June 1, 2004 Author Report Share Posted June 1, 2004 also4: i cant run games From my CD drive...I have to stick them in the DVD drive.... Quote Link to comment Share on other sites More sharing options...
expertec Posted June 1, 2004 Report Share Posted June 1, 2004 Does the CD drive show up in device manager? Quote Link to comment Share on other sites More sharing options...
Andy-2004 Posted June 1, 2004 Author Report Share Posted June 1, 2004 yes Quote Link to comment Share on other sites More sharing options...
Rebel=UK= Posted June 1, 2004 Report Share Posted June 1, 2004 Right click on it and got down to properties, see if all is well Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted June 1, 2004 Report Share Posted June 1, 2004 have you got nero installed. Quote Link to comment Share on other sites More sharing options...
ranger Posted June 1, 2004 Report Share Posted June 1, 2004 I have had a cd burner go this way and basically it was the laser that had gone or managed to get misaligned, I had to buy a new one Quote Link to comment Share on other sites More sharing options...
Andy-2004 Posted June 1, 2004 Author Report Share Posted June 1, 2004 have you got nero installed.no i dont...i recently changed case....... Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted June 1, 2004 Report Share Posted June 1, 2004 I think your cdr has had it so you may as well try a firmware update http://www.burnworld.com/firmware.htm or http://forum.rpc1.org/dl_all.php Quote Link to comment Share on other sites More sharing options...
Andy-2004 Posted June 1, 2004 Author Report Share Posted June 1, 2004 i cant find the make of my CD RW..... Quote Link to comment Share on other sites More sharing options...
Andy-2004 Posted June 1, 2004 Author Report Share Posted June 1, 2004 is there anyway this problem could be caused by connecting somthing wrong inside the pc? Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted June 1, 2004 Report Share Posted June 1, 2004 ok best way to find out is to use xp's own built in cd writing software,you may get more info that way. Quote Link to comment Share on other sites More sharing options...
Andy-2004 Posted June 1, 2004 Author Report Share Posted June 1, 2004 sorry...use the build in softare to do what?find out what the CD RW is or to burn a test CD(ellas 5000 posts :o) Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted June 1, 2004 Report Share Posted June 1, 2004 burn a test data(not the ISO) cd,if it burns ok you know it related to other s/ware,if it does not it will give you probaley more info to why not. Quote Link to comment Share on other sites More sharing options...
Andy-2004 Posted June 1, 2004 Author Report Share Posted June 1, 2004 i keep getting this message no matter what i use.... Quote Link to comment Share on other sites More sharing options...
Boris Posted June 1, 2004 Report Share Posted June 1, 2004 Right click on it and got down to properties, see if all is wellWorking OK ?Make ?Model ? Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted June 1, 2004 Report Share Posted June 1, 2004 have you tried a different bland of disc.what the hells a bland :D brand Quote Link to comment Share on other sites More sharing options...
Andy-2004 Posted June 1, 2004 Author Report Share Posted June 1, 2004 i dont have any othersI cant find out the name of my drive....all i can find isATAPI CD-RW 52X MaxAnd in DM it says its working fine Quote Link to comment Share on other sites More sharing options...
Agent Smith Posted June 1, 2004 Report Share Posted June 1, 2004 Andy, bearing in mind that you have just changed to a new case, may I suggest that you open your machine up and check that ALL the connections are good and secure. (And that includes the motherboard end of the IDE cable).Also, when you moved the devices from the old case, have you altered any positions at all? For example were the Cd and Dvd using the same ide cable in your old case, and are they using the same cable now? Are they connected to the same connectors on the cable as before, or have you swapped them around, in which case you may need to change your master and slave jumpers. In fact are the jumpers set to master and slave, or are one or both on cable select? If so I would set them manually.Check this first, I would be inclined to think that this is something caused by your case swap at the moment.Mr. M. Quote Link to comment Share on other sites More sharing options...
Andy-2004 Posted June 2, 2004 Author Report Share Posted June 2, 2004 yes it did...I changed case on the thursdayBurned 2 music CDs on fridayplayed games for a few days...and then when i started to get error messages when starting games saying please insert the correct disk and restart the application. I assume this was when the burning problem started as well but i hadent needed to burn a CD untill i wanted to the otherdayEDIT: i even installed RH9 like 4 days ago Quote Link to comment Share on other sites More sharing options...
