Laptop Hard Drive Temperature
I've got a temperature monitoring utility on my hard drives in my desktop PC and laptop. On the desktop the hard drive temps are now at 21oC and 28oC (both have a cooling fan fitted).
The temp on my laptop drive is showing as 50oC but it rises to 60oC under load (virus scan/Adaware scan). That's the same as my desktop CPU under load. Is this normal or is it scary? :unsure:
Ambient temperature in the room is 24oC.
The program is from http://private.peterlink.ru/tochinov/
I don't have a laptop so I couldn't compare, but if you think about it, there isn't much space inside a laptop for airflow.... so perhaps that is normal. What is a normal temp for a hdd to run at? :huh: Hmmm well I just did a bit of googling and that seems pretty run of the mill to me! :)
I'm assuming (and hoping) that it is normal for a laptop drive but it does seem high. I've been unable to find any detailed specs for the laptop (Sony Vaio PCG-FX405) so am a bit in the dark about it.
I appreciate the sensors may not be too accurate but running the temperature utility on my desktop PC at least confirms that it reports the same temperatures as the utility supplied with the motherboard.
I was hoping someone on here would be able to give me a clue what their laptop drive temperature is as a guide/reassurance.
Sorry mark2 and Nel, I didn't refresh before posting so didn't see what you'd said.
mark2, thanks for that, it's the reassurance I was looking for. As my Pentium 2.6 runs at similar temps to the laptop drive I was a little concerned that a hard drive was reaching those temperatures.
