Partition problems caused by Drive Image
I was running XP Home and installed Drive Image. Running that program I selected to create a Disk Recovery Manager partition on my C drive. After the program created this partition the computer rebooted but Windows couldnt load. I cant read the drive at the command prompt and transferring the drive (as a slave) to another computer shows it as not accessible. Im a novice at this so following advice from a friend I have tried to remedy the problem with Partition Magic but was not successful.
Any suggestions or pointers as to where to look would be gratefully received. :(
Drive Image cannot create partitions as far as i know, so are you using drive image or some other program? Or do you mean Partition Magic?
If you cannot gain access to the drive with a command prompt you've probably zapped the partition. If It ain't there no more and all data has gone :(
In what way, meesage on screen or you have nothing to access?
Creating a disk recovery partition on the same HDD is probably not a good idea, as if the HDD fails, the chance of getting the data back yourself is slim.
You'd be better off saving your data to another drive (as in a type of RAID setup), or to CD (or DVD now).
I have never used Drive Image, so I write with much ignorance. But do you know what type of partition you created? (With Partition Magic you have the option to create partitions for other operating systems).
Windows XP still needs a MBR (master boot record) - otherwise it simply won't boot.
Did you try booting up your PC when pressing the F8 button? You then have an option of booting the PC from It's last known working install.
Of course the most drastic option is to reinstall from your XP CD...
Good luck!
Try booting from your xp CD and going to repair console and type, 'fixmbr' and 'fixboot'
Might wipe out your newly created partition, but should work.
Sounds promising Scarecrow but booting up with XP disk and selecting Repair just results in a command prompt. :(
Do you have the partition magic or bootmagic floppies ?
Sorry, I don't see how this will help.
I have established that the files are present on the C drive and could copy the important ones to my new drive but reinstalling all my apps and settings could take days so if there is any way to make the drive bootable would by a great boon.
I've checked and the main partition is active.
In that case, it was the software (Drive Image as you say) that has caused the problems. You need to use the recovery disks (which I know you made......... right?) If not, there isn't much you can do besides format?
Try going to Drive Image's website and contacting them about what happened. They may have a solution for you.
