Sir Radfordin Posted May 5, 2003 Report Share Posted May 5, 2003 Feeling a little bit nosy on a Monday afternoon...If you have XP set up as it should be (none of this classic nonsense!) then what does it show about your computer use? What the top applications you are using, and what have you 'pinned' to the start menu?To start it all off:PinnedInternet Explorer (someone has to carry on using it)Pegaus MailLotus OrganiserStart MenuDealer EditWS_FTPDreamweaver MXWordNotepad (!)Windows Media PlayerDrive Rescue (it wasn't me who lost 2 assignments!)Command Prompt (long live dos)ExcelVery boring isn't it :rolleyes: Quote Link to comment Share on other sites More sharing options...
Prince of Calcutta Posted May 5, 2003 Report Share Posted May 5, 2003 even more boring! :rolleyes: Quote Link to comment Share on other sites More sharing options...
mark2 Posted May 5, 2003 Report Share Posted May 5, 2003 I'm not really paranoid Quote Link to comment Share on other sites More sharing options...
peter e Posted May 5, 2003 Report Share Posted May 5, 2003 Here's mine... Quote Link to comment Share on other sites More sharing options...
Guest spikeychris Posted May 5, 2003 Report Share Posted May 5, 2003 If I had to use the XP start menu I'd just use 2K.....Chris Quote Link to comment Share on other sites More sharing options...
Guest Nellie2 Posted May 5, 2003 Report Share Posted May 5, 2003 Right well I'm feeling a bit left out in this one........real XP users......ha!!!! Here is a picture of my very pretty start menu that has nothing to do with XP but still works very well thankyou. :P Quote Link to comment Share on other sites More sharing options...
Tankus Posted May 5, 2003 Report Share Posted May 5, 2003 Ok....... for the retards amoungst us..... (aka ...me ! ) .... how do you take a "still" of your star menu and post it ....... Duh.............?Nasty colours ...nellie ? Quote Link to comment Share on other sites More sharing options...
Guest Damo Posted May 5, 2003 Report Share Posted May 5, 2003 Just 'print screen' to clipboard then crop it in a photo editing package :ph34r: Quote Link to comment Share on other sites More sharing options...
Tankus Posted May 5, 2003 Report Share Posted May 5, 2003 huh.... ok ..... duh...... Quote Link to comment Share on other sites More sharing options...
Guest Nellie2 Posted May 5, 2003 Report Share Posted May 5, 2003 That is photo editor that turns it that colour......honest!!.....anyway, what is wrong with plum!!!!The way I do it is press print screen, the little button just to the right of your keyboard, usually above your delete key somewhere.......open up microsoft photo editor, click on new, then paste and the picture of what is on my screen is pasted into photo editor, I then crop off the bits I don't want and 'save as' somewhere then post. Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted May 5, 2003 Report Share Posted May 5, 2003 just got m/soft paint on this one,do one tomorrow with psp on other puter Quote Link to comment Share on other sites More sharing options...
Tony Posted May 5, 2003 Report Share Posted May 5, 2003 Here's mine Nothing special. Quote Link to comment Share on other sites More sharing options...
Guest Shirley_Crabtree Posted May 5, 2003 Report Share Posted May 5, 2003 Just the usual for me. Quote Link to comment Share on other sites More sharing options...
Daisymay Posted May 5, 2003 Report Share Posted May 5, 2003 I think mine's probably really boring! :blink: Quote Link to comment Share on other sites More sharing options...
Agent Smith Posted May 5, 2003 Report Share Posted May 5, 2003 OK everybody, here's what a real start menu should look like.Mr. M. Quote Link to comment Share on other sites More sharing options...
Guest Damo Posted May 6, 2003 Report Share Posted May 6, 2003 Well here's mine.......nice skin eh? ;) Quote Link to comment Share on other sites More sharing options...
artist Posted May 6, 2003 Report Share Posted May 6, 2003 Re. How to get the pic on here - What am I doing wrong?I tried your way Damo but when I go into PSP , it's there but not looking like the start up menu - just a list in a window.Tried your way Nell and only got a window with the dimensions, size etc. Also the 'paste' is greyed out. When I press the 'print screen' nothing happens - should it? :( How did you get on Tankus? Quote Link to comment Share on other sites More sharing options...
Guest Nellie2 Posted May 6, 2003 Report Share Posted May 6, 2003 Ok........1. Get your desktop how you want it to be and press PrtScrn..........nothing will happen, it will just copy a picture of your desktop to the clipboard.2. open MS photo editor3. click the far left icon for 'new' (the one that looks like a piece of paper.4. a box entitled 'blank picture will pop up.....mine shows resolution 100% width 99.99 and hieght 99.99 click ok,5. when you click ok a blank white square will show.....as long as something is on your clip board then when you right click it will paste onto the square.........then you can fiddle with it. Quote Link to comment Share on other sites More sharing options...
artist Posted May 7, 2003 Report Share Posted May 7, 2003 Oh, Gawd! I haven't tried yet but I haven't got a m/s photo editor. I HAVE got a photo thingy on my HP printer prog and also PSP. I have got a blank brain on this one. Help! :huh: :o I appreciate this thread will be dead by the time I find out how - but I still want to know ............. Quote Link to comment Share on other sites More sharing options...
Guest spikeychris Posted May 7, 2003 Report Share Posted May 7, 2003 Even easier >>>Just click start so that the start up menu appears. Then hit the Print Screen button. Open up Microsoft Paint and click edit at the top of the screen and click paste, this will place the image on screen. You then have the option of cutting it down to fit.Chris Quote Link to comment Share on other sites More sharing options...
Sir Radfordin Posted May 7, 2003 Author Report Share Posted May 7, 2003 thats all very interesting isn't it ;) Should I be surprised that nearly all of us are still making use of notepad? Is this the best thing ever to come from Microsoft? Quote Link to comment Share on other sites More sharing options...
Paul Posted May 7, 2003 Report Share Posted May 7, 2003 Heres mine, very boring.Oh and Im in the notepad club too :P Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted May 7, 2003 Report Share Posted May 7, 2003 this is my other puter as boring as the first,just a different av <_< Quote Link to comment Share on other sites More sharing options...
Guest ellas Posted May 7, 2003 Report Share Posted May 7, 2003 Tankus,artist heres a shareware program fo you :D http://www.wugnet.com/shareware/spow.asp?ID=258 Quote Link to comment Share on other sites More sharing options...
artist Posted May 8, 2003 Report Share Posted May 8, 2003 I have downloaded it. Thanks. :) Quote Link to comment Share on other sites More sharing options...
